Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 08-29-2012, 07:45 PM   #1
101fng
Drives: 2009 Mustang GT
ZL1 vs G8 GXP
ZL1: Stock
G8: Tires only
Ready.....
GO!
opinions?
101fng is offline   Reply With Quote
Old 08-29-2012, 07:47 PM   #2
Brettzel
Brettzel's Avatar
Drives: #null
Brettzel is offline   Reply With Quote
Old 08-29-2012, 08:24 PM   #3
L99CAMA2011
L99CAMA2011's Avatar
I know, I know, start a fire under the ZL-1 kill it with heat soak and then the G8 would win.
L99CAMA2011 is online now   Reply With Quote
Old 08-29-2012, 08:28 PM   #4
LBV
LBV's Avatar
Drives: G8 GXP manual
585 hp vs 415 hp on the same platform with the same weight (give or take) = ZL1 win.
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro!
Borla cat-back, H&R springs, & Sprintbooster & I love it!
LBV is offline   Reply With Quote
Old 08-29-2012, 09:45 PM   #5
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
This thread is full of win.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 08-29-2012, 10:07 PM   #6
101fng
looking at track times, i figured it'd be a little closer than the facepalms might suggest.
ok, so stock ls3's a no-go. cam and tires?
cut me some slack here, i'm ****ing LSx retarded. the big weight advantage plus tires seems like it could've been a good race. just bench racing here. and do me a favor, let's not refer to manufacturer hp ratings. i think we all know how accurate those are in the real world (especially when boost is involved)
Old 08-30-2012, 10:37 AM   #7
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
ZL1 should smoke it, BUT look at the times posted by real drivers. If the G8 can run 13's, it could very well win. There's a big difference between what Chevy says the car will run, and what it's actually running.
E.T. is offline   Reply With Quote
Old 08-30-2012, 11:59 AM   #8
101fng
that's what i'm saying. sure, low-12's have been had in a stock ZL1 but most of the time it's in the mid-12's. the G8 is a 13-even car stock, so how much would it really take to put it into the mid-12's (ZL1 territory).
Old 08-30-2012, 01:57 PM   #9
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Find me someone who's run 13 flat in a G8 bone stock. What GM says and real world numbers are totally different things.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 08-30-2012, 02:43 PM   #10
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
A well driven bone stock GXP on radials will run high 12s. An average driver will drive a ZL1 to mid-to-low 12s blowing the stock tires off.
http://www.dragtimes.com/Pontiac-G8-Timeslip-22332.html 12.93 at -6xx DA
http://www.dragtimes.com/Pontiac-G8-Timeslip-23400.html 12.95 with BMR Trailing Arms, Non-Adjustable Toe Rods, Poly Cradle Bushings, 1450 DA
http://www.dragtimes.com/Pontiac-G8-Timeslip-19751.html 13.12 with a dogshit 2.1 60'
http://www.dragtimes.com/Pontiac-G8-Timeslip-19252.html 13.16 with a 1.9 60' but a dogshit 2200 DA.
Please tell me you don't do much drag racing.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 08-30-2012, 02:52 PM   #11
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
those gpxs are quick
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 08-30-2012, 03:07 PM   #12
E.T.
E.T.'s Avatar
Looks like Motortrend got: 13.0 sec @ 109.6 mph
http://www.motortrend.com/roadtests/...t/viewall.html
There's a difference between mag times and what real drivers are going to get the first time they go to the track, though. I doubt an inexperienced driver would be able to pull off a time like that without some practice.
Old 08-30-2012, 03:13 PM   #13
motorhead
Drives: POS MOPAR
Why not just do a ZL1 VS prius thread. The result would be the same. Asswhoop'en either way.
Old 08-30-2012, 04:05 PM   #14
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
If the ZL1 is stick with an average driver the G8 has a reasonable chance.
DarkneSS is offline   Reply With Quote
