Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Texas > Local Marketplace
Old 08-30-2012, 10:02 AM   #1
GoPaul
H-Town Camaro Club
GoPaul's Avatar
Drives: 2010 Black Camaro 2LT RS M6
V6 Modded Engine Cover
Thinking of selling my modded engine cover as I opted for a different route after installing my painted & ported Intake Manifold (and it no longer fits..)
Just wanted to put the feelers out to see if anyone would be interested in buying it - I will need to replace the LED's and tidy it up a little first but before I start I thought I'd see if I have any takers?? tip - lesson learned - cover is best used to install for car shows etc and mild driving only, my LED's burnt and discolored a little as I left it on and drove with it on daily.
$125 takes it. PM me if you want it, first come, first served.
Picture of my modded engine cover:
Best Timeslip: <Time Slip> Latest Dyno (w. Injen only): <Dyno Sheet> Journal: <Here>
GoPaul is offline   Reply With Quote
Old 09-03-2012, 10:19 AM   #2
RamboLucille
Drives: 2012 Camaro 2LS
That's a gorgeous cover to bad mines a daily driver.
RamboLucille is offline   Reply With Quote
Old 09-07-2012, 12:39 AM   #3
BACH
Delving the Ordure ...
BACH's Avatar
Drives: '10 2SS/RS 6M CGM, '94 Z-71
Bumpish
Me: Hey babe, do you mind if I spend a little money on my car?
Wifey: Your hobbies are expensive...(deep sigh). How much this time?
My journal: http://www.camaro5.com/forums/showthread.php?t=164741
BACH is offline   Reply With Quote
Old 09-07-2012, 01:09 PM   #4
Capt_Pooty
Slow Race Vert
Capt_Pooty's Avatar
Drives: 2011 2LT Vert
What are you thinking on price, I may be interested ???
Capt_Pooty is offline   Reply With Quote
Old 09-18-2012, 08:42 AM   #5
GoPaul
H-Town Camaro Club
GoPaul's Avatar
Will let it go for $125.
Old 09-18-2012, 11:10 AM   #6
Wakemaker89
Wakemaker89's Avatar
Drives: 2010 Obsidian Lexus IS-F
Send a message via Skype™ to Wakemaker89
Get it Capt! that would look great on your vert!
Anyone selling a Camaro5 shell or SS with blown motor?
Wakemaker89 is offline   Reply With Quote
Old 09-19-2012, 12:45 PM   #7
Shuffler
God Bless Dawson
Shuffler's Avatar
Drives: Synergy for my Daughter
That is a great deal for someone.
Shuffler is offline   Reply With Quote
Old 08-22-2013, 11:35 AM   #8
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
what did you use to cut the plastic on the engine cover? and where did you hook up the lights to? (power source)? im thinking of doing this soon
Jalberdi99 is offline   Reply With Quote
Old 08-22-2013, 12:09 PM   #9
GoPaul
H-Town Camaro Club
GoPaul's Avatar
I drilled a couple holes to insert a jigsaw and then made the cut outs using that. I then sanded down the edges first using a file to get the lines symetrical and then sandpaper to take away the roughness.
For the lighting , I ran a cable direct to the fuse box (their is a main positive connection right at the front of it). For the negative I ran a cable down to the chasis somehwere (can't quite remember to be honest) but any earthing point will work. I then used easy snap connectors at the ends of both cables and this allowed me to connect the cables from the engine cover and disconnect easily when I wanted to remove the cover.
