Flowmaster Exhaust
View Poll Results: The transmission temp gauge in your car is...
Lower than the picture with an aftermarket torque converter 3 60.00%
Higher than the picture with an aftermarket torque converter 0 0%
Equal than the picture with an aftermarket torque converter 0 0%
Lower with STOCK torque converter 2 40.00%
Higher with STOCK torque converter 0 0%
Equal with STOCK torque converter 0 0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 08-30-2012, 09:54 PM   #1
locoycabron
Drives: 2010 Camaro SS
Hows your transmission temp?
my auto transmission seems to be runing hotter than normal after i installed a 3200 torque converter.
i did not took the precaution to see the gauge temp before the upgrade.
im also runing a flex-a-lite 4116c transmission cooler with the stock cooler canceled.
the temps im showing in the picture are driving at 79• outside temp and while driving around 85 mph on highway.
how are your gauges normally? lower than this?
locoycabron is offline   Reply With Quote
Old 08-30-2012, 10:04 PM   #2
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Celsius?
FASTER than my SS....for now
2500HD (with a couple parts)
Originally Posted by Coyotekiller View Post
I wonder if this could be why my car idles like its retarded...
GaBoy25 is offline   Reply With Quote
Old 08-30-2012, 10:10 PM   #3
locoycabron
lol yeah celcius wild guess would be the position of the needle since on the farenheit gauge your red bar should be at 320 degress or not?
Old 08-30-2012, 10:10 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
mine runs 150-170*f (65*c - 76*c) all the time with the b&m HI-TEK supercooler/fan, no radiator cooler, monitored from the dlc with dashawk
the cooler you are using is really pretty cheap design and not very efficient compared to the plate design coolers like this one:
http://www.summitracing.com/parts/BMM-70297/
i have used this on many builds and it always works great!
Old 08-30-2012, 10:15 PM   #5
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2016 Charger Hellcat
That seems really high.
lewylew is offline   Reply With Quote
Old 08-30-2012, 10:23 PM   #6
locoycabron
your cooler is 24,000 GVW?
vs my 16,000 GVW
Old 08-30-2012, 10:30 PM   #7
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Seems a little too warm for just cruising on the highway. What happens to it on a hot day, or in stop and go traffic?
BTW, why run the heater and A/C at the same time?
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 08-30-2012, 10:30 PM   #8
camaro1
camaro1's Avatar
vs my 16,000 GVW
b&m is rated at 30,000 GVW,,,
you want the largest cooler with the most surface area that you can fit,, the b&m plate cooler is 12" x 13.5" and 3.5" thick!!
the standard tube coolers like yours are not very efficient as you can see by your temps compared to mine with the same stall converter
Old 08-30-2012, 10:31 PM   #9
locoycabron
cause its cold! lol i needed a little more hotter air
Old 08-30-2012, 10:37 PM   #10
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Mine runs around 180 unlocked, and 145 cruising on the highway locked. It has reached 200-205 in traffic before, but thats about as high as it goes.
pouncer72 is offline   Reply With Quote
Old 09-01-2012, 04:18 PM   #11
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Mine stays around 180 with a 3400 TCI Stall, no cooler.. Not sure about the track yet, waiting on tires.
Nitroman28 is offline   Reply With Quote
