sjm autoprod
Old 09-01-2012, 08:52 PM   #1
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Water softener/filter
First off I searched, no haters please!
Someone had posted that they found a water softener for an RV that they used to help combat water spots on their Camaro. It was fairly in expensive and I think it came from Walmart?
Anyone else remember this or knows what I'm talking about?
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 09-01-2012, 09:24 PM   #2
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Hope this helps out, this is what I use.
http://www.allfilters.com/rvwaterfil...-rv-700-rv-800
etmx183 is offline   Reply With Quote
Old 09-01-2012, 10:03 PM   #3
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
I have one from Costco called CR Spotless De-Ionizing Water System made by Spotless Water System. It wasn't cheap, about $400 but filters the water pretty good and our water here is awful. It's fairly large and on wheels like a small welding setup. The filter will get dirty, so I only use it to rinse the car.
2012 2SS Convertible
Magnuson, Headers, Cam, JRE Tune. 563 HP.
Lee123 is offline   Reply With Quote
Old 09-01-2012, 10:05 PM   #4
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
I have a water softener system for my entire house, and then that goes into a whole house water filter that filters chemicals and sediment out, then that goes out into the autogeek water filter/softener before it hits my car.
So, it is filtered 4 times and softened 2 times.
The water here is horrendous and they have to heavily treat it.
jimmy5 is offline   Reply With Quote
Old 09-02-2012, 10:20 AM   #5
soniccj7
soniccj7's Avatar
Drives: 2010 1SS/RS IBM
I really miss the MrClean car wash. It came with a filter for rinsing the car.
soniccj7 is offline   Reply With Quote
Old 09-06-2012, 09:24 PM   #6
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
Just ordered it I have 179 miles on my new ZL1 and am waiting for a whole lot of stuff from Adams. This step was also mentioned by a respected detailer/friend of mine as one of his secret weapons.
Thanks for posting this I hope more people consider it
charlietuna is offline   Reply With Quote
Old 09-08-2012, 09:32 PM   #7
DFWHD
Drives: 45th Anniversary Convertible
I read this thread when it started and decided to order the Culligan RV800 from Amazon. I used it tonight and was extremely pleased with the results.
Thanks to etmx183 for providing the info!
Sent from my iPad using Tapatalk HD
DFWHD is offline   Reply With Quote
Old 09-10-2012, 10:30 AM   #8
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
You have two options:
Water Softening- This replaces hard water mineral ions with sodium ions (basically a salt exchanger). With a water softener you will may get some light water marks but they are not water spots, just sodium residue that wipes away easily.
Water Softening Solutions
Water De-Ionizing- A water deionizer, such as the CR Spotless removes the hard water mineral ions so that the water is completely clean. This is a more expensive option but one that will leave absolutely no water spots.
CR Spotless Systems
