Solo Performance
Old 09-02-2012, 07:41 PM   #1
Nessal
Drives: Exige, Miata, Ghia
40+ degree of timing advance
So I'm doing some data logging today and my Torque program on my Android is showing that I have 40 degree of timing advance.
What the heck is going on? BTW, I'm using the preconfigured PID that came with torque.
Nessal is offline   Reply With Quote
Old 09-02-2012, 07:55 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
timing is all based on engine load/airflow and rpm if you are just cruisin at light throttle you may have 40+ * timing thats normal,,,
now if you said that you had 40* timing at wot then you would have issues
Old 09-02-2012, 10:15 PM   #3
NC-V
NC-V's Avatar
Drives: cts-v
yep, Stock timing maps have upwards of 45* in low load/rpm areas
NC-V is offline   Reply With Quote
Old 09-11-2012, 12:09 PM   #4
LIVEVIL
LIVEVIL's Avatar
Drives: Camaro
The lighter the load on the engine and the slower the engine turns the more timing one needs to achieve good power. So it's perfectly normal to run 40+ degrees of timing while cruising or just driving around lightly.
At full throttle you will never see this.
LIVEVIL is offline   Reply With Quote
Old 09-11-2012, 06:37 PM   #5
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Try cruising on the interstate where there is no grade and you'll be even more surprised. Mine runs between 52 and 53 degrees advance at 72 MPH.
2SSCAMARO is offline   Reply With Quote
