Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 09-03-2012, 01:02 AM   #1
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
Most important tools to own?
I am new to working on cars, so I want to start my collection of tools that I need for when I work on my car or just do some car maintenance. What is the most important tool(s) to own??
Aubrey64 is offline   Reply With Quote
Old 09-03-2012, 02:47 PM   #2
Synner
Drives: not stock
Standard and deep socket sets, some extensions for the sockets, wrenches, torque wrench, good screwdriver set. A good jack and some jack stands. I have ramps but rarely use them because they don't get the car up far enough for my liking. I'd just do the jack/stands. A good multimeter is dirt cheap and will help you check your battery and finding hot wires.
That's really all you need starting out. It kind of depends what you want to do and what you consider "working on" your car.
Old 09-04-2012, 03:40 PM   #3
Flashpoint135
Rev Head
Flashpoint135's Avatar
Drives: 2016 SS
The above plus make sure you get a set of "body tools". They come in sets of 4 to 6 different shapes that look like small plastic pry bars. They are used to take out all the different body clips and to release panels without breaking the clips or marring the panels. They are cheap.
Also - Make sure you get a good quality deep socket for the lug nuts. And make sure the floor jack has a low enough profile to fit under the front of the car.
Flashpoint135 is offline   Reply With Quote
Old 09-04-2012, 03:46 PM   #4
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
low profile jack and shop towels for sure, get some GOJO! like others have said, socket set is also a must.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 09-04-2012, 04:06 PM   #5
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
You'll be advised to buy the best you can afford; that is true to some extent - but, since you are not a professional making $$$ from your tools, you can afford to economize somewhat.
If you have access to Costo:
http://www.costco.com/Browse/Product...=1&topnav=&s=1
RiCorvette is offline   Reply With Quote
Old 09-04-2012, 05:30 PM   #6
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
BFH - for those special modification projects
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 09-04-2012, 07:22 PM   #7
jordan 572
jordan 572's Avatar
Drives: none
jordan 572 is offline   Reply With Quote
Old 09-04-2012, 11:02 PM   #8
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
The Craftsman Club at Sears has saved lots of money in the past. Not the best tools, but great warranty and functional. Can't afford Mac or Snap-On for a weekend hobby. Even better, raid the Dad's tool box or find an estate sale. I thought I had a pretty complete set while rebuilding dirt toys, but the Camaro has some odd size metric stuff. More sockets and wrenches are better...
Mods: JRE 470 cam kit, Dynatech long tubes/hi-flo cats, SLP underdrive pulley, CAI intake/ADM scoop, Pfadt Stage 2 suspension, Hotchkiss strut tower brace, Proven Wicked tow hook and end links, DBA rotors, Melling oil pump, Katech timing chain/LS2 damper, some bloody knuckles, still in progress...
gotroost is offline   Reply With Quote
Old 09-04-2012, 11:07 PM   #9
babytiger
it's hers...
babytiger's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
an LED flashlight
babytiger is offline   Reply With Quote
Old 09-05-2012, 12:34 AM   #10
Redemption
Just Because!
Redemption's Avatar
Drives: 2010 SIM 2SSRS
Beer fridge.
Redemption is offline   Reply With Quote
Old 09-05-2012, 01:08 AM   #11
midnighter
Drives: nothing
Sobriety
Old 09-05-2012, 01:15 AM   #12
sene
Drives: 2011 Summit White 2LS
I would say start with a good basic mechanics kit or set and then keep adding as you go
sene is offline   Reply With Quote
Old 09-05-2012, 04:27 AM   #13
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
knowledge, a good friend, and small hands.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 09-05-2012, 06:37 AM   #14
destroyerofu2
xbox360 tag
destroyerofu2's Avatar
Drives: 2010 inferno orange 2SS
or a good friend with small hands. (had to play this card in the past while working on my camaro)
start small and buy as needed.
Originally Posted by babytiger
And like destoryerofu2 said, WOT should be a moment of silence...
It's mine, like it or not. http://www.camaro5.com/forums/showthread.php?t=108079
destroyerofu2 is offline   Reply With Quote
camaro, important, maintenance, tools, work
