Cold Air Inductions
Old 05-29-2009, 01:46 PM   #15
LDGn63
LDGn63's Avatar
Drives: WNABEE
i think i saw on a G8 site that the LOUDMOUTH system is basically a muffler delete...
is that true for the camaro too?
BTW, this is sweet!
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 05-29-2009, 05:31 PM   #16
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
No I am sorry for mis stating the pipe material. These are aluminized metal not stainless. I called the installer and he said he would try to make some extra pipes when the next one comes in but in reality this is pretty custom pipe bending and hanging to get the pipes centered and at the right angle to keep the factory exhaust look out the back. I have to tell you that after driving it some today, and the comments I have got from friends and folks that pull along side at stop lights. This exhaust has really made a difference. The thing I love is all the engineering GM put into the sound is not lost it is enhanced.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 05-29-2009, 05:38 PM   #17
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
He's done a good job at centering from the pics' that I've seen. It can't be to easy to get them to align like that, but they look good.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 05-29-2009, 05:56 PM   #18
m0ore4ustin391
m0ore4ustin391's Avatar
Drives: 2009 Cobalt SS
Lol, finally someone did it. If it passes for inspection this is what i will be doing when i get my Camaro! Thanks for posting, sounds awesome for a muffler delete.
m0ore4ustin391 is offline   Reply With Quote
Old 05-29-2009, 06:00 PM   #19
96rss/ls6
Inferno is the only color
96rss/ls6's Avatar
Drives: 96 ls6 camaro, iom 2ss/rss /
so we need some dyno #s here, Im sure it picked up something. someone do this and dyno there car so we can see what we are working with
96rss/ls6 is offline   Reply With Quote
Old 05-29-2009, 06:04 PM   #20
96rss/ls6
96rss/ls6's Avatar
Isnt the exhaust assemmetrical, wouldnt you just make one to fit one side then copy for the other?
Old 05-29-2009, 06:07 PM   #21
DDustiNN
DDustiNN's Avatar
Drives: Soon: 2016 Camaro SS
Wow, that sounds great! Especially for the price!
DDustiNN is offline   Reply With Quote
Old 05-29-2009, 06:14 PM   #22
Stevo
Drives: Camaro 2010 SIM
Nice, great job, inexpensive , probably shaved some weight off too...about how much do those mufflers weigh anyway?
Stevo is offline   Reply With Quote
Old 05-29-2009, 06:15 PM   #23
NAHURRY
Love's to Detail
NAHURRY's Avatar
Drives: 2010 SS,97silverado/08crewcab
Thats what I will do! this sounds awsome! Anybody know were I can
get this done in the Greenville/Greer area?
NAHURRY is offline   Reply With Quote
Old 05-29-2009, 06:18 PM   #24
2010 SS RS
2010 SS RS's Avatar
Well in a perfect world or if perfection was not important you could do that. However to get everything lined up and in the center of the factory hole it was a process of bend fit and bend and fit until everything was just right. I am sure that some of the kits can come pretty close and they are getting another camaro in a few days so they will play around and see if they can come up with an acceptable kit. Other issue is the tip. I used the original factory tip but as a kit the unit would more than likely have to have a different tip already installed. Not a bad thing cause there are some real cool tips available.
Old 05-29-2009, 06:19 PM   #25
2010 SS RS
2010 SS RS's Avatar
I would say about 15 lbs each at most.
Old 05-29-2009, 06:25 PM   #26
96rss/ls6
96rss/ls6's Avatar
Yeah im in greer and I have an awesome guy to do it. do you have your car yet
Old 05-29-2009, 06:25 PM   #27
DkknightX
Drives: 2006 Chevrolet Cobalt SS/SC Stage 2
Awesome! Now THIS is what I'm talking about. Don't need fancy mod kits that cost tens of thousands more. Solutions like this are a little more realistic. Thanks!
DkknightX is offline   Reply With Quote
Old 05-29-2009, 06:27 PM   #28
96rss/ls6
96rss/ls6's Avatar
I thought you meant the pipes centering the back of the car fro underneath. As far as center of the hole goes that shouldnt be a problem, you should have exhaust hangers that hold them in the center of the hole.
