Old 06-04-2009, 12:04 AM   #113
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Originally Posted by Davis View Post
Got my straight pipes put in today and all I can say is !!
No drone, no noticeable difference at highway cruising speeds, great idle and sounds like a beast when you get on it.
Perfect!
Thank you for giving it a try and reporting the same damn thing......I love mine more every day. Had a cop pull me over today to look at car. He loved it as well. No problem or issue just a fantastic low cost mod that should be considered before spending the big bucks for a fancy name brand system. I am telling you that the GM engineering on this exhaust will blow you away!
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 06-04-2009, 12:02 PM   #114
caverman
caverman's Avatar
Drives: '69 SS Convertible
Perfect!
Any info about using a different metal than what the factory exhaust is? Do muffler shops usually carry the same type of material (not sure what it is) as the factory exhaust? That would be my only concern. Would the different metals really cause a problem.
Did you use the factory tips or have different ones put on? Any pics you can give as well?
Just out of curiousity what did you have to pay. Not that I think $200 is high....I would pay $200 in a heartbeat over the $1,500 Corsa wants for their cat back system (which from what I've heard in the videos doesn't sound any better).
Thanks for all the feedback. This is all great stuff. I would much rather put the money difference for an Air Filter or Headers or High-Flow Cats.
Build Journal
Old 06-04-2009, 12:14 PM   #115
Davis
Davis's Avatar
Drives: '10 Black 2SS/RS M6
I had the shop use 409 stainless 2.5" pipe, with stainless wire for the welds.
I used the factory tips.
I agreed to time and material with the shop. Since this was the first 2010 Camaro they had even touched, they took their time. They spent a lot of time with centering the tips. I paid $300.
It's been raining here for several days, but I'll try to get some pics up soon.
I'm very particular with these things and IMO Larry's (2010 SS RS) tips are perfect. Mine are slightly off, but it was late and we were all tired. The shop has promised to make it right if it really bugs me. But we'll see. I've asked a few people to look at it and most just say.."What did you do? It looks the same."
I can't go on enough about the sound. It sounds really really good.
The full cat-backs may pick up a few extra ponies, I dunno.
If you are doing LT's and high-flow cats it might get a bit obnoxious, but stock it's perfect.
Black, 2SS/RS, Manual, Inferno Orange Accent Trim Pkg, Sunroof, Rear Ground Effects
Tinted Windows, DT shorty headers, !mufflers, !CAGS, Barton STS, Vararam
VIN# 2G1FT1EW5A9101443
Delivered 4/17/2009
Davis is offline   Reply With Quote
Old 06-05-2009, 06:21 PM   #116
3 SS's
3 SS's's Avatar
Drives: Chevelle SS's
Yep, this is the route for me... unfortunately the shop that did the exhaust on my 69 Chevelle SS has since closed :( , gonna have to find someone else.
3 SS's is offline   Reply With Quote
Old 06-06-2009, 12:01 AM   #117
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
I'm scheduled with the exhaust shop to have this done on Tuesday. His shop is respectable and has been around for quite some time.
However, he does not have any stainless in that Dia. on hand and he would have to buy a 10' piece if I wanted it. He told me Aluminized Steel would do just fine for what I want and I'm wasting money using stainless.
Have a slight feeling he just would rather take the easier path especially after the comments about the bends he needs to make.
He figured it would cost me $130-140 to have it done with the steel.
I plan on checking a couple more places tomorrow.
Scourage is offline   Reply With Quote
Old 06-06-2009, 06:57 PM   #118
2010 SS RS
2010 SS RS's Avatar
I have the aluminized on mine. Sure when you mix metal there is the corrosion issue. But the fact of the matter is that the jerry cans removed were not stainless steel. And furthermore, my car wont see rain and other corrosives that could accelerate the issue. I feel very confident that this set of straight pipes should last for at least 10 years and more than likely more. Stainless is better without a question but you could do it twice with aluminized. Sound would be the same. And allignment might be better cause it is so much easier to bend.
Old 06-06-2009, 07:06 PM   #119
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Removed Mine!!! Thank you so much 2010 SS RS and Davis. Let me go on the record to say this is by far the best mod for this car. My Guy here says he will assemble with polished stainless and stainless tips for $225 plus shipping. He only does custom work. Let me say that this car sounds incredible. Love the low pop while slowing. Drove on Interstate 90 mph no problem no drone.
lawdogg149 is offline   Reply With Quote
Old 06-06-2009, 11:44 PM   #120
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
How is the sound level in the car. I do not need it quiet, but I do not want it super loud either.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 06-07-2009, 12:31 PM   #121
Scourage
Syntax Error
Scourage's Avatar
Went to another shop yesterday, he basically told me the same thing. Aluminized would be much more cost effective, won't discolor like stainless, going to last a long time and he'll warrantee it for three years.
He took a quick look and told me it would cost about $60 and take 1/2 hour to do. I think that might be a little under estimating since he didn't really get under there and see the bends he needs to make.
He has done something similar to a few Chargers and a Challenger.
I now have an appointment with these guys tomorrow
Old 06-07-2009, 05:31 PM   #122
2010 SS RS
2010 SS RS's Avatar
Right on. Seems like this is really starting to take off now. I have someone (another member) that is getting me some specs to modify the stock air intake. When I get it I will post a step by step video to modify and open up the air intake without spending 470.00. I cant wait as this is the obvious second part to the muffler delete.
Old 06-08-2009, 12:25 AM   #123
caverman
caverman's Avatar
Can you get us some pics and contact info for you muffler shop guy?
Wouldn't it be better even if you had to spend just a little more money to have one custom bent so that they can get the muffers centered or would copy of a previous install probably get you close enough?
Build Journal
Old 06-08-2009, 05:03 PM   #124
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
Great mod!
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP Graduate, A.S. Automotive Technology, Telecommunications Specialist, CISCO Certified Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is online now   Reply With Quote
Old 06-08-2009, 07:11 PM   #125
MerlinZero
Big Orange
MerlinZero's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
I REALLY like this sound.... this is what i'm kinda looking for.... Something that rivals those loud ass V8 Vantage's that run down 405 all the damn time.
" First, there was darkness, Then, On March 16th, Scott said LET THERE BE CAMARO, and there was Camaro, and Scott saw that it was good. Camaro5 3:16"
VIN: 2G1FT1EWXA9120523
ETA 7/6/09 (Delivered 7/10/09)
MerlinZero is offline   Reply With Quote
Old 06-08-2009, 10:27 PM   #126
2010 SS RS
2010 SS RS's Avatar
I really think you guys that have tried it all have come away with the exact same feeling......WOW! GM has this exhaust tuned perfect for the mod. Still trying to get the details on a CAI mod that uses the existing housing and mass flow sensors. I will post as soon as available or if you guys figure it out let me know.
