Old 09-04-2012, 01:06 PM   #1
Late Model Racecraft
Late Model Racecraft's Avatar
Drives: 98 Camaro Race Car 3.96 @ 202 MPH
Late Model Racecraft ZL1 Videos
Late Model Racecraft is offline
Old 09-04-2012, 01:10 PM   #2
Old 09-04-2012, 06:16 PM   #3
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Do you think covering up the radiator cost you a few HP?
Trackman is offline
Old 09-05-2012, 03:25 PM   #4
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 2014 SS sedan
care to disclose who tuned the Black 708 RWHP car?
Current toy-02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles.
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline
Old 09-06-2012, 10:20 AM   #5
We Tuned It over here at LMR
Old 09-06-2012, 11:02 AM   #6
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
What mods does the black car have?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline
Old 09-06-2012, 11:09 AM   #7
ZL Camaro 700hp+ Package:
-Solid isolator
-2.55” upper pulley
-Upper pulley hardware kit
- Dowel pin
- Pulley cap
- Alignment dowel pin
- Bypass positioning tool
160* Thermostat
LMR Cold Air Induction System
10% overdrive harmonic balancer
65 lbs/hour fuel injectors
Stainless Steel Longtube headers with high flow cats
MSD 8.5mm Spark Plug Wires
NGK Spark Plugs
LSA Comp Cam Kit, Comp Custom Grind Cam Shaft, Comp Double Valve Spring kit good for .675 lift, Titanium Retainers, Spring Seats, Valve Seals, and Comp Chromoly Pushrods
All necessary Gaskets/Fluids
Installed and Dyno Tuned
Old 09-06-2012, 01:06 PM   #8
KD Innovations
Drives: 2012 ZL1, 2009 CTS-V
KDi HX?
KD Innovations is offline
Old 09-06-2012, 01:08 PM   #9
Keith, yes the Black one did have yalls heat exchanger on it. Thank you it worked great
Old 09-06-2012, 02:31 PM   #10
thespymaster
thespymaster's Avatar
Originally Posted by Late Model Racecraft View Post
Very cool video..................
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
thespymaster is offline
Old 09-06-2012, 02:32 PM   #11
KD Innovations
Thanks for the feedback.
Old 09-06-2012, 02:35 PM   #12
KD Innovations
Do you mean with a HX? I can say the ECT and IAT2 temps have no issue at all in over 100 degree heat with the HX placement. Very valid design question though and thoroughly tested.
Old 09-24-2012, 05:12 PM   #13
Ben69
Ben69's Avatar
Drives: 2013 VR ZL1
Can you pm the prices for your ZL1 packages? Whats the turn around period for the installation?
Ben69 is offline
