Old 05-29-2009, 12:54 PM   #1
FriedCherry
Drives: 2010 2SS/RS IOM/IO Camaro
HeadLight / DRL question
I didn't get the RS. However I want my fog lights to be the DRL, not the HeadLights. Can this be changed by changing the wiring?
Thanks
FriedCherry is offline   Reply With Quote
Old 05-29-2009, 01:13 PM   #2
JDBeck23
Drives: 2010 Camaro, 2SS/RS
sure... you can try putting a jumpering the DRL hot lead to the fog lights hot side. Dont see the point though.
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 05-29-2009, 01:20 PM   #3
FriedCherry
I do NOT like DRL at all. IF I would would have known that before I ordered, I would have gotten the RS just for that reason alone.
Are DRL required by law? If not I could just disable them completely?
Old 05-29-2009, 01:22 PM   #4
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Depending on what status your order is you can probably change it to add the RS package.
UCF w00t is offline   Reply With Quote
Old 05-29-2009, 01:57 PM   #5
FriedCherry
Its at 3800.
Old 05-29-2009, 03:20 PM   #6
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
Fried Cherry - just be sure you realize the Halo HIDs of the RS package cannot be on at the same time as the DRL as stock (unsure if you can mod them). Its either DRLs or Halos in running lights.
I'd prefer to be running the Halo as DRL- its been cloudly/rainy in NJ most of the week so I've been driving with running lights on - Halo's, side markers and tail lights.
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 05-29-2009, 03:46 PM   #7
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
http://www.hidkit.com/Chevy-Camaro-HID-Kits/ I was trying to find a bulb for a friend of mine and came accross this site. The bulbs for his G-35 are 93.00 dollars Looks like the camaros are in the same price range. Talk about a pain, you had to pull 4 clips off and go threw the the inner wheel well. Never had HID's before, they look brite.
69 Hugger is offline   Reply With Quote
Old 02-09-2010, 01:51 PM   #8
Bone
2SS RJT OWNER/OPERATOR
Bone's Avatar
Drives: 2010 2SS LS3 RJT
Thanks
I too would like to change th DRL. On the non-RS the head lights are the DRL. I would like reverse the DRL to the fogs. Has anybody rewired there lights in this way? If so. Could someone direct me to the thread. I looked thru the appearence thread but could not find anything on this topic. Or post instructions and/or pics.
thanks
Fly low and Avoid the radar!
Bone is offline   Reply With Quote
Old 02-09-2010, 02:09 PM   #9
CALI_FIREFIGHTER
CALI_FIREFIGHTER's Avatar
Drives: 2LT/RS SIM
Open the front of the fender well by the front tire. Remove the bottom three torx screws. You will see a blue hot wire going to the side marker lights. Run a wire tapped into the hot wire on the side marker to the DRL. Hot wire is purple on drivers side and brown on passenger. Now your DRL's will turn on in day light and stay on when headlights come on.
CALI_FIREFIGHTER is offline   Reply With Quote
Old 02-09-2010, 02:59 PM   #10
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
On the non-RS models, the headlight selector knob has a push button in the middle for the fog lights.
You can also turn the DRL's off completely (as well as the auto lighting feature) by turning the headlight selector knob left to the off position and letting go.
Old 02-09-2010, 05:55 PM   #11
Bone
Bone's Avatar
Actually, on the non-RS you can have both the headlights and the fog lights on at the same time already. The headlights are the DRL. The center push button on the light switch will turn on the fogs while the DRL are on. Not a problem. As I stated earlier. I want the Fogs to come on as DRL. and them the center button would turn on the headlight. It can't be much more that switching the leads directly at the switch or somewhere down the line. But I'm not an wiring tech. I just need to be shown how to do it. Pics would be great... Photos are worth a thousand words. Thanks again.
Old 02-09-2010, 06:04 PM   #12
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Wired my LS head lights to come on with the side marker lights, no more DRLs. The Fog lights now are triggered by the previous headlights/DRL making them DRL/foglights. Had to use two 40A DPST relays to properly trigger but it is really simple to do.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 02-09-2010, 08:10 PM   #13
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
You can definitely mod the DRLs to come on with the halos. AAC Style sells the wiring kit to do it with instructions. Here are the instructions:
http://www.camaro5.com/forums/showpo...5&postcount=96
I bought the LEDs from them to replace my DRLS and they gave me the wires to do that mod for free. It is easy.
Old 02-11-2010, 12:48 PM   #14
redneck2420
redneck2420's Avatar
Drives: 2010 Camaro LS IBM w/White Strpies
Could you post a DIY on this?
redneck2420 is offline   Reply With Quote
Halo and Headlight Operation Question 5th_GEN_SS 5th Gen Camaro SS LS LT General Discussions 42 04-13-2009 08:52 AM
OK WILL SOMEONE PLEASE ANSWER THIS QUESTION OM FINANCING leatherneck Camaro Price | Ordering | Tracking | Dealers Discussions 22 03-26-2009 03:53 PM
Halo headlight question BigSlik 5th Gen Camaro SS LS LT General Discussions 68 03-24-2009 06:45 AM
Headlight Question Croathlete 5th Gen Camaro SS LS LT General Discussions 40 02-25-2009 07:06 AM
Headlight question lafountain 4th Generation Camaros 0 06-16-2008 09:52 PM
