BORLA
Old 09-05-2012, 05:35 PM   #1
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Using a Different ECM?
Can I buy a different ecm and have it tuned and be able to switch the 2 out? Tuner wants me to send my ecm in so he can make adjustments, so If i can swap ecm out I wont have any down time. Thanks for any info on this..
Nitroman28 is offline   Reply With Quote
Old 09-05-2012, 06:19 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
I don't know the answer but a quick search shows that getting another ECM is not easy and there might be an issue with the mileage discrepancy between the two ECMs
http://www.camaro5.com/forums/showthread.php?t=104772
Old 09-05-2012, 06:21 PM   #3
ec1990
Drives: 2012 AGM SS
On a previous car I did this, and if it's the same the odometer isn't stored on the ECM it's on the BCM. The ECM primarily controls engine tuning only. I don't know if this carries over though.
ec1990 is offline   Reply With Quote
Old 09-05-2012, 06:35 PM   #4
Nitroman28
Nitroman28's Avatar
Yea I read that but being an old post i thought there may be some new info on it..
Old 09-05-2012, 07:55 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
I tried one, never got all the codes to clear. It had my VIN programmed into it. Crankcase position, security, clutch learn.
If you got one and knew someone that could flash it at a dealership you might pull it off.
Iam Broke is offline   Reply With Quote
Old 09-05-2012, 08:07 PM   #6
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Can you buy a new ECM and have it tuned?.....Yes
Can you switch the two out?......Yes BUT you will have down time and you will need to get your car hauled to a dealer for ECM flashing whenever you switch ECMs. The replacement E38 no start ECM you purchase will need to be flashed by a dealer after it is installed in your car. It would be flashed with a stock tune which would not work very well with modded engines especially any that have bigger than stock injectors, blowers, turbos, cams, etc. There is also a security flash needed to enable the car to start. The starter will not even engage without the security flash. There are better ways to have your car remotely tuned, i.e. email tunes.
2SSCAMARO is offline   Reply With Quote
Old 09-05-2012, 11:41 PM   #7
Nitroman28
Nitroman28's Avatar
So I take it, It's a no to my question.. Thanks for the reply
Old 09-06-2012, 07:51 AM   #8
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
You will also have to get the ECM and the TCM married or they will not work properly.
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 09-06-2012, 08:00 AM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
That doesn't work. Search and you'll find tons of threads on it.
Click to view my build thread
Old 09-16-2012, 04:13 AM   #10
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
That's what I had to do, bought a second ECM and got it tuned while I sent my original out to get unlocked from the previous tuner. After that I had two ECM's tuned, one for E85 and one for 91.
Scourage is offline   Reply With Quote
