Old 09-06-2012, 08:47 AM   #1
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
Hoosier 28x10-17 need tubes?
I know this is tires so it probably goes in the tire section, but I figure there is a much better chance the people in here have first hand experience?
I am ordering some Hoosier 28x10-17 slicks today as I noticed my M&H's are now dead Should I get tubes for the slicks or run without? My car is not very fast (11.9 @ 9,000DA).
Are there any pro's/ cons to tubes?
Current tire :(
AngelSpeedFreak is offline   Reply With Quote
Old 09-06-2012, 09:00 AM   #2
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
I have 20 passes on my Hoosiers without tubes and have had no issues. I played with tire pressure from 11 to 20 lbs and found 14.5 lbs. seems to work good for my car.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 09-06-2012, 09:22 AM   #3
Supercharged SS
Drives: 2010 Camaro
Unless you plan on screwing the tires to the wheels you won't need tubes.
Old 09-06-2012, 09:30 AM   #4
AngelSpeedFreak
Bryan
Thank you
Old 09-06-2012, 07:01 PM   #5
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
jamie will tell you, if you have 700rwhp range, you prob might want to consider screws..
mikepage0007 is offline   Reply With Quote
Old 09-06-2012, 08:40 PM   #6
Supercharged SS
Drives: 2010 Camaro
Ha! At least mark the valve stem on the tire and make sure they don't spin on the wheel. I was spinning my tires have way around the rim.
Good memory old man!!
Old 09-11-2012, 10:39 AM   #7
carbon8
Drives: 2010 Camaro SS,2008 Hayabusa
The tubes will help with side sway on the big end. What rims and tires are you running up front? I just want to make sure you running a skinny.
Slicks feel a whole lot diffrent then DR.
carbon8 is offline   Reply With Quote
Old 09-11-2012, 01:08 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
If you don't run tubes and screws, I'd mark them for sure.
Only downside to not running tubes is sometimes my slicks would go flat pretty quick. There is some sort of trick using liquid soap or something to use between the wheel and slick that helps it from loosing air too fast, maybe search on that. Might be a good thread on on YB.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-20-2013, 03:03 PM   #9
Blue70SS
Blue70SS's Avatar
Has anyone had a problem with the Hoosiers going out of round? I noticed on the return road from the track that the car seemed unusually bumpy, but had written it off to adjusting rear coilovers to full stiff. I put the rear on jacks and let the tires spin at idle and have quite the hop on my LR tire..... about 3/8" of an inch, but everything looks good otherwise. Used them for 1 test-n-tune night (about 7 passes), Sturgis Camaro Rally 1/8th mile, and 6 passes at Bandimere's Super Chevy 2013. Lots of tread still.
LPE Brotherhood
Old 08-21-2013, 08:28 PM   #10
Allanski
Drives: Car
I have searched for 17 inch tubes and did not find any available?
If you know where to get some let me know please.
Allanski is offline   Reply With Quote
Old 08-21-2013, 08:35 PM   #11
Supercharged SS
Drives: 2010 Camaro
Maybe the wheel is out of round.
Old 08-21-2013, 08:35 PM   #12
Supercharged SS
Drives: 2010 Camaro
The largest I've seen are 16's. Ill poke around.
Old 08-21-2013, 09:31 PM   #13
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
As Jaime knows, my tires are screwed to the rims and I do not have tubes in them...just have to be diligent about checking the air pressure... Which as racers we can be a bit anal about that anyway...
Old 08-22-2013, 09:32 AM   #14
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
What screws did you use? I bought the 1/4" x 3/4" screws Mr.Gasket but the same as Moroso and others and I measured the tire andwheel thickness and the both are only 5/8" so the screw would go through the tire and for sure cause a leak, I did not install them and was going to try to find some 1/2" long ones.
Also if the screws go through wouldn't it pop the tubes, if it had tubes?
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
