Old 09-06-2012, 09:05 AM   #1
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
17's VS 18's
I have only made a few passes down the track on stock tires and I am hooked...except for the traction.
I just started researching wheel and tire combos for the back and it appears I could spend a bag of money on custom made 17" wheels or I could simply purchase some 18 vette replicas for the back. As a novice will I see any noticeable gains with 17's? If I purchase 18's will I kick my self later when I want that extra tenth or two?
When it comes to tire selection should I look for a tire with similar height to stock? (nearly 28")
Trackman is offline   Reply With Quote
Old 09-06-2012, 09:16 AM   #2
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
If your hooked as you say then you'll always want that extra tenth or two. That being said, go for the 17's. I bought mine from Rich at Bogart and their great. You can get Hoosiers from:
Gee and Gee Racing in Leduc.
5601 45St
Leduc Alberta T9E 7B1
780-986-7223
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 09-06-2012, 09:46 AM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
The big thing about 17's is that Hoosier makes a really nice drag slick for them (28x10-17). There are NO true 18" drag slicks available from any manufacturer. So, with 18's you will always be stuck running a drag radial (not a bad thing, unless you get serious about your drag racing). With 17's, you can run either....
blazzin1 is offline   Reply With Quote
Old 09-06-2012, 09:56 AM   #4
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
Love my 17's... so glad I went this route instead of Z06 rims. Now I just need to find some 17's for the front.
AngelSpeedFreak is offline   Reply With Quote
Old 09-06-2012, 07:25 PM   #5
Trackman
Trackman's Avatar
I like the idea that 17's have the ability to have slicks. At this point I will be driving the car to and from the track so I will start with drag radials. Now I just need to figure out the differences between ZL1 and SS for backspace and clearance issues with brakes etc.
Old 09-06-2012, 08:00 PM   #6
blazzin1
blazzin1's Avatar
I know I've seen pictures on here of a ZL1 sporting 17" Weld RT-S Wheels. Not 100% sure if they are the same offsets as what is recommended for the SS, but I would guess so. You could try calling Weld and ask them directly???
Old 09-06-2012, 08:36 PM   #7
Supercharged SS
Drives: 2010 Camaro
Yes, ZL has same offsets and the SS. I know the guy that had those wheels on. They use to belong to Scottywheels.
Ted will have my 17" Bogarts and 325 drag radials on his zl tomorrow at the rental.
Old 09-06-2012, 09:32 PM   #8
Trackman
Trackman's Avatar
Please update tomorrow on how they fit and run down the track .
Old 09-06-2012, 09:36 PM   #9
Supercharged SS
Drives: 2010 Camaro
They fit great. Just like on the SS but I'll see how they do at the track.
Old 09-06-2012, 09:47 PM   #10
Trackman
Trackman's Avatar
Sorry, last Q, I do not want to make a very expensive mistake.
Did they bolt right up or was there modifications to calipers,hoses or control arms? Are they 9.5's with 40mm offsets? Or wider?
Old 09-06-2012, 09:55 PM   #11
Supercharged SS
Drives: 2010 Camaro
They bolt right up. You just need to tie back the ebrake cable. Teds car is 100% stock. Im sorry I don't know the specs in the wheels. Bogart doesn't make that public. If for some reason it doesn't work out tomorrow with then I'll let you know. Im assuming they have then on his car already. I haven't heard otherwise. Just don't go ordering anything until Monday!!
They are 10" wide. That I do know.
Old 09-07-2012, 06:27 PM   #12
Supercharged SS
Drives: 2010 Camaro
The 17" Bogarts bolted right on at the track today. No issues. I don't even think you need to tie back the ebrake cable since its relocated on the ZL do to the wider wheels.
Hope this helps.
Old 09-07-2012, 07:58 PM   #13
Trackman
Trackman's Avatar
Thank you very much. Are there any issues with not having tire pressure sensors?
What did Ted run on the front?
What did you guys learn from your testing?
Old 09-07-2012, 08:02 PM   #14
Supercharged SS
Drives: 2010 Camaro
No issues with no tpms. After a ton of passes or some miles driven the light will come on but that's it. Ive had some kind of bogart on for 13 months straight with no issues.
Ted ran the stockers up front. He didn't see the need for the skinnies.
I learned that teds zl is slow!! 12.0-12.1 at 114-116 completely stock in 3000 da. The DR's dead hooked and he cut 1.8 60's. He just needs to tune it up.
I would say unless you're going past 550 rwhp save your money and go with 18's.
