Old 09-06-2012, 01:55 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
LG Motorsports G5 Adjsutable sway bar package
Hey guys,
Looking for a bolt on upgrade to keep your Camaro flatter in the corners and add some grip?
One of the easiest ways to flatten your car in the corners would be to bolt on a set of sway bars. Our bars are a massive 35mm in diameter front and rear and are made of a tubular design so that weight is not an issue using a bar of this size.
We have included three adjustment points front and rear so you can custom tailor the stiffness of the car front and rear and also set the bars front and rear bias as you would like for your needs.
Powder coated in a hard finish they will last you a very very long time.
Kit Includes:
Front three way adjustable bar
Rear three way adjustable bar
Front bushing
Rear bushing
Front end link with hardware
Rear end link with hardware
Bars, bushings, and end links
Installed with LG Drop springs, front
Installed with LG Drop springs, rear
One Lap Camaro
*Notice the front wheel off the ground
Bars also sold with out the end links, and end links are also sold separately.
Anthony @ LG Motorsports is offline   Reply With Quote
