BORLA
Old 09-08-2012, 09:24 PM   #1
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
Welds and m and h 325s having trouble
Tried unsuccessfully all day to get into the tens , so close 11.008 x 2 times. Just can't get 0 to 60 under 1.76 128 mph excellent reaction times??? Put 2/3 tank of fuel in , I just don't know. Can't power on in first or I break loose. 15,5 pounds air. Mega 2nd gear burnouts. Any takers
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 09-08-2012, 09:49 PM   #2
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
you should do better 60ft for sure I did a 1.72 on a 305/35 R20 Nitto 555 drag radial. Can you slip the clutch more and ease out for the first few feet to get the car moving instead of trying to launch it hard.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 09-08-2012, 09:53 PM   #3
Supercharged SS
Drives: 2010 Camaro
Mega burnouts on a drag radial is no good. All you're doing is making the tire greasy. With a dr just burnout until they wisp smoke. That's it. And fill the gas tank completely full.
Full slicks would help a ton. With the m6 you really need to have a dialed in suspension.
Old 09-08-2012, 10:08 PM   #4
bcguy
bcguy
bcguy's Avatar
okay will fill up tank all the way,less burnout,try and feather clutch but fn hard with this standard and have a consistant 0 to 60 ,if car was lighter life would be good
Old 09-08-2012, 10:11 PM   #5
Supercharged SS
Drives: 2010 Camaro
If these cars were lighter everyone would be in the 10's!!. It's not easy getting a 4200 lb car to go fast. If you can't run a slick I would focus on a full out suspension. Not cheap but extremely effective.
Old 09-08-2012, 10:22 PM   #6
bcguy
bcguy
bcguy's Avatar
so what do you have in mind for full suspension mods for 1/4 mile,the problem is i just bought my 17s welds,i guess over winter i could find some smaller brakes and buy some 15 inch rims and slicks ,i dont believe there is a 17 inch slick(let me know if i am wrong)also if i run true slicks then that would move me from pure street.its kind of nice to be high tens in a street car
Old 09-08-2012, 10:28 PM   #7
Supercharged SS
Drives: 2010 Camaro
Just because you run a slick doesn't mean you won't have a 10 second street car. I take my car on 6 hr, 400 mile trips. Change tires and hit the track.
If you want to make it work with a drag radial I'd do drag race specific shocks, solid bushings, toe rods, trailing arms, larger rear sway. Basically, if I had an M6, I would get every suspension part I could on it.
Hoosier makes a 28x10x17 full slick. Everyone runs them.
Old 09-08-2012, 10:37 PM   #8
bcguy
bcguy
bcguy's Avatar
well i gues i will finish the season with what i have,hope i will get lucky tomorrow,im so close
Old 09-08-2012, 10:40 PM   #9
Supercharged SS
Drives: 2010 Camaro
Gd luck!! You are knocking on that door. You have more than enough mph. Even with a crappy 60' you'll get it. Try walking the car out then hammering it.
Old 09-09-2012, 06:29 AM   #10
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
We always found the M&H's do in fact LIKE a good, big burnout...
Also 15 PSI might be a bit low for a drag radial... with a radial if you don't have enough air in them they will actually start cupping in the center and you'll lose part of your contact patch... I would start around 26 PSI.
scrming is offline   Reply With Quote
Old 09-09-2012, 09:58 AM   #11
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
i found that 17psi worked the best for me on M&H's.
AngelSpeedFreak is offline   Reply With Quote
Old 09-09-2012, 02:28 PM   #12
bcguy
bcguy
bcguy's Avatar
Well Im running a 1.68 0 to 60 so the full tank of fuel is helping. 11.1 and 11.058 qualifying runs going to dial in at10.99. What do you think
Old 09-09-2012, 02:59 PM   #13
Turbo99
Turbo99's Avatar
Thats a good 60ft, make sure your car isn't heat soaked and do what you can.
Old 09-09-2012, 03:04 PM   #14
bcguy
bcguy
bcguy's Avatar
Yep brought ice to lay on blower this time we are good
