Emblempros
Old 09-09-2012, 08:27 AM   #1
Squintah
Squintah's Avatar
Drives: Camaro EU 45th Anniversary Edition
Change FE3 to FE4
Hi there,
is it possible to build the shocks and the springs of the FE4 suspension in a model with an FE3 suspension? I want to sell my fact and have a prospect with a 2010s Camaro.
Thanks in advance and best regards,
Björn.
Squintah is offline   Reply With Quote
Old 09-09-2012, 08:24 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Not sure what the question is but I know its possible to buy fe4 shocks and springs and install them. But for the price of buying new parts im just planning on buying FE6 1LE shock and springs to go with my zl1 sways
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 09-09-2012, 09:37 PM   #3
z28racer
z28racer's Avatar
Drives: 12 SIM 2SS/ RS Sinergy M6,GMC2500HD
Just get Eibachs!
z28racer is offline   Reply With Quote
Old 09-10-2012, 12:17 PM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
You can definitely upgrade an FE3 equipped car to an FE4 suspension package. It will require swapping out the rear control arms and purchasing new rear end links... but it definitely can be done. The shocks and springs are interchangeable between all of the model years.
We offer an OEM Upgrade package for FE3 owners who want to run our ZLSpec sway bar package. It includes everything you need to install our sway bars onto an FE3 equipped car:
  • New OEM Rear Control Arms
  • New OEM Rear endlinks
  • New Front Pfadt endlinks to bolt the ZL Spec sway bars to your FE3/FE4 shocks
This package when paired with the ZL Spec sway bar package can turn any 10-11 SS Camaro into a well balanced machine that should give any ZL1 a run for it's money.
