SDTW Custom Wheels & Tires
Old 09-09-2012, 04:33 PM   #1
hognutz
hognutz's Avatar
Drives: 2013 ZL1
DIY MILD TO WILD for ZL1 or newer camaro with dual mode exhaust
Okay as requested I will post this up. Sorry it is not step by step pictures but mine is done already. If anybody wants help doing thier's or can contribute better pics of each step I will edit as needed. If I need to get back in the trunk I will take better pics.
~cost $25 and 1hour to complete the task.
Parts required
1. remote relay of some kind I used RM02
http://www.amazon.com/LOGISYS-RM02-r.../dp/B000PI9E4K
2. fuse tap
http://www.amazon.com/Pico-0956pt-Mi...=pico+fuse+tap
3. ring termail (I had these but here is an example)
http://www.amazon.com/Install-Vinyl-...rminal+14%2F16
4. spade terminal (I had this as well but here is an example)
http://www.amazon.com/Scotchlok-Viny...le+terminal+18
5. zip ties/wire loom
6. double sided foam tape
tools required
1. wire stripers
2. crimpers
3. 10mm socket
4. rachet
5. plastic fastener remvoer (not required but helps)
6. dremel tool (not required but helps notcht he fuse box for the wires)
7. test light
8. tin snips or cutter of some kind
Steps
preparing the RM02 for install
1. crimp the two ground leads of the RM02 to the ring termial
2. Crimp the spade terminal to the 12V out lead of the RM02
3. Trim down the spad to fit the width of one side of the fuse box (use tin snips)
4. Crimp read wire from the FUse tap to the 12v in lead of the RM02
5. Unstick one side of the foam tape and put it on the back of the RM02
Remove the trunk panels
1. remvoe the rear trunck panel
2. remove the pansenger side panel.
3. remove fusebox lid (push on the two tabs)
4. remove F8 and F3 fuses
Install
1. remove 10mm ground ground bolt and place the ring termal with ground lead from the RM02 on it and re-install bolt
2. place 20amp fuse in the bottom position of the fuse tap and 10 amp fuse in the top position of the fuse tap.
3. insert fuse tap into F3 position
4. insert Spade into lower position of F8 fuse location.
5. Turn the relay(RM02) on with the remote and verify volate at F8.
6. stick RM02 unit with double sided tape near the fusebox
7. use zipties to tie wires to existing loom to tidy up intall
8. Notch top slot of fusebox with a dremel to so the wiers will slide through the slot.
9. re-install fuse box lid
10. re-install truck panel.
this RM02 unit can also be used with your homelink bottoms.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 09-13-2012, 12:26 PM   #2
toehead93
Drives: 2014 2SS/1LE
Sweet, thanks for sharing. I just need the NPP exhaust now (waiting to pull the trigger on a 1LE).
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 01-11-2013, 01:05 PM   #3
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2018 Silverado
Great DIY... Super easy to do and I think it's less than 20 bucks now..
Old 03-17-2013, 07:43 AM   #4
swhitney2003
Drives: none
mlee, is the relay retentive, that is will it be in the same position (on/off) the next time you start the car or does it always default to one position?
If F3 has a constant 12V with the vehicle off this should be the case, but then my concern is current draw while the vehicle is off.
swhitney2003 is offline   Reply With Quote
Old 03-21-2013, 10:03 AM   #5
RoadMonkey
that's how we do it
RoadMonkey's Avatar
Drives: '13 ZL1 / M6 Summit White
..."It's All Good" -Todd formerly maddog360
-drives: '13 ZL1/M6 Summit White
-rides: Harley-Davidson FLHRSE5 110ci-aka Road King
'86 Buick Grand National...mine since '99..a few mod's and never "finished"but I love her...
'10 Camaro SS/RS A6 Summit white - Sold
'13 ZL1/A6 Victory Red - SOLD..
'02 Camaro SS/SLP 6spd - ** FOR SALE **
RoadMonkey is offline   Reply With Quote
Old 04-05-2013, 11:05 PM   #6
ARod221
SoCal HT5 (SD)
ARod221's Avatar
Drives: 2006 4Runner
can we get a sound clip?
My Build Thread 2013 AGM 2SS/RS ***SOLD***
http://www.camaro5.com/forums/showthread.php?t=374535
ARod221 is offline   Reply With Quote
Old 04-29-2013, 07:28 PM   #7
slim-n-none
slim-n-none's Avatar
Drives: 2013 AGM 2SS RS M6 (sold)
The link to the add a circuit is for a regular sized fuse, the fuses are the minis. And do i need to leave the fuse for the flaps out once i install the spade end?
slim-n-none is offline   Reply With Quote
Old 04-29-2013, 08:35 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
the fuse for the flaps stays out because you putting the spade in back in place of the fuse.
your sourcing voltage fromt the F3 location and then the relay is applying the voltage back into the F8 location that your removed.
the link says mini-fuse and that is what I ordered
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 04-29-2013, 08:57 PM   #9
slim-n-none
Thanks for the reply, going to see if it makes a difference on the way to work in the morning. I think i got it all hooked up right, i can hear the relay clicking when I push the remote buttons, but if I cant tell a difference I'm going to yank it back apart and make sure the spade end stayed hooked up, if the spade wasn't hooked up, the baffles would stay open all the time, correct?
Old 04-29-2013, 09:04 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Originally Posted by slim-n-none View Post
Thanks for the reply, going to see if it makes a difference on the way to work in the morning. I think i got it all hooked up right, i can hear the relay clicking when I push the remote buttons, but if I cant tell a difference I'm going to yank it back apart and make sure the spade end stayed hooked up, otherwise the baffles would stay open all the time, correct?
all you have to do is rev the car to about 4500-5k in the car there will be a night and day difference.
with the flaps open at idle its a little tricky to tell without giving it a rev.
If I remmber right the spade goes in the bottom connection of F8 but yeah if you put it in the top connection they would just be open at all times.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 04-29-2013, 09:45 PM   #11
slim-n-none
Went back and checked. Looks like somewhere along the way, the wrong one got put in my cart. Oh well, I have anther place to use it so no big loss.
Its going to be fun downtown in the morning with the exhaust echoing off all of the buildings.
Old 10-04-2013, 12:30 PM   #12
woyster_13ss
woyster_13ss's Avatar
Drives: 2013 IOM 2SS
Just did this...AWESOME! Thanks for the great how-to instructions.
Ordered 4/24/2013...Built week of 5/13/13...Delivered 6/7/13
2013 Inferno Orange Metallic Chevrolet Camaro 2SS/RS
6.2L V8, NPP, Manual 6-Speed, GM Performance Shifter, Cold Air Inductions CAI, Bo White's Stage III Ported TB, Sunroof, Window Tint, Gen5DIY Halo & DRL Harnesses, 5000k LED DRL Bulbs, APEX Skip Shift Eliminator, Hood Spears / Front & Rear Blackout Panels / Gills from Big Worm Graphix, Gary's Customz Front & Rear Painted Bowties, Powdercoated Wheels & Camaro Badges, Painted Calipers, Plastidipped Taillight Bezels
woyster_13ss is offline   Reply With Quote
Old 10-21-2013, 10:58 AM   #13
CamaroIOM12
Jim
CamaroIOM12's Avatar
Drives: 2013 2SS Camaro Convertible
Just did this this weekend, thank you OP great wright up . IMO I think there's a big difference in sound I am a happy man!!!!!
"I'm that one shot one kill bringer of fate"
CamaroIOM12 is offline   Reply With Quote
Old 10-22-2013, 09:02 PM   #14
toehead93
Do you think thisrelay and remote will work? I like the clean look they have.
http://www.amazon.com/Remote-Central...ay+with+remote
2010 2SS A6 - sold.
