Old 09-15-2012, 06:33 PM   #29
Hercules
Drives: 13 ZL1 1091, 04 Ram 2500, 12 CX9
Thanks for the good in depth instructions regarding the installation of the catch can. Really helps those of us that like good pics with directions!
Hercules is offline   Reply With Quote
Old 09-25-2012, 09:39 PM   #30
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
No problem! I like to have my stuff detailed.
I once did a whole series on how to build a guitar from scratch, but it was too long to put on youtube and my computer messed up with the editing of the video.
jimmy5 is offline   Reply With Quote
Old 09-26-2012, 10:39 AM   #31
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
Jimmy did you ever get a chance to see how much oil you trapped over XXX miles?
MY Car
2013 ZL1 Vin 555
Details
Crystal Red Tint Coat/ Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
6 Spd Manual
Road Trip To Buffalo complete shipment from MO has arrived
closs2sx is offline   Reply With Quote
Old 09-26-2012, 10:56 AM   #32
Snakedriver
Snakedriver's Avatar
Drives: ZL1
How do you remove the engine cover?
Snakedriver is offline   Reply With Quote
Old 09-26-2012, 11:01 AM   #33
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
6 foot crow bar and a BFH
Just gently lift it up, it is mounted in Rubber gromets.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 09-26-2012, 12:46 PM   #34
jimmy5
jimmy5's Avatar
No, because I think there may be a few drops in there at this point. I am waiting to see what I have after a few thousand miles, not a few hundred.
Old 09-29-2012, 09:58 AM   #35
zl1bro
Drives: 2013 ZL1 M6 SIM AGM mono stripe
Is there a large advantage to going with a dual valve over the single valve? Prefer to keep things simple unless there is good reason for not..
zl1bro is offline   Reply With Quote
Old 09-29-2012, 10:34 AM   #36
hognutz
hognutz's Avatar
Drives: 2013 ZL1
It only takes an extra 15min to install the dual. 1/2 dill into the intake tube and intake tube comes off in 1 min.
I will let them chime in with the tech but if if you call them the will explain to to what they recommend the dual valve.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 09-29-2012, 12:11 PM   #37
zl1bro
Thanks for the clarification. I will get in touch with them. Proly end up going the dual valve route. What's one extra tube in the engine compartment anyway?
Old 10-01-2012, 07:14 AM   #38
JANNETTYRACING
None that I know of.
KISS is a good Rule.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 10-15-2012, 04:07 PM   #39
ZL1Reaper
ZL1Reaper's Avatar
Drives: '13 Silver Ice Metallic ZL1
Hey guys.
I received my can this weekend. I can't wait until I install it, but I have a couple questions. Where to I attach the clear hose from the bottom of the can? And, to check for oil in the can, do I have to disconnect the couplings and invert the can?
Thanks for the help.
Cass
ZL1Reaper is offline   Reply With Quote
Old 10-15-2012, 04:27 PM   #40
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
Cass, the clear hose is the drain so you can attach it to what ever you want, or leave it hanging. Don't run it into the pulleys or belts though. I just shortened mine up a bit so it wasn't rubbing on anything.
Whenever you decide to drain any possible oil accumulated in the can run the hose into some small container, and open up the threaded valve the hose is attached to. No can removal or inversion necessary. Gravity will pull any oil out then close up the valve and go about your business.
tsnow is offline   Reply With Quote
Old 10-15-2012, 07:15 PM   #41
ZL1Reaper
ZL1Reaper's Avatar
Okay. Thanks. Easier than I was picturing.
Old 02-24-2013, 01:17 AM   #42
alyssasdad
Go VOLS!!!!!
alyssasdad's Avatar
Drives: ZL1 #1344 VR, M6
I know this thread is old but since Jimmy has shown how to install a catch can about the best of anybody I've seen,I've got a question.First off,I just got my catch can from Tracy, and plan on installing it tomorrow. Mounting the can seems easy enough but I'm wondering one thing. How the hell can you get close enough to the original little hose that has to be snapped off!!! I guess if you took off that big black round thing and all those little lines running in and out of it and maybe took the belt off it would not be as difficult, but everybody says its real simple and takes an hour or less. I guess I just want to clarify this : You can install a Rx catch can with a flathead screwdriver and a socket wrench(used to install the can on the bracket and the bracket on the car). Just using the supplied hose(that you cut in half) and all you have to do is take the engine cover off. Is this correct? Even if you can get the little connecting hose off( with only touching it with a flathead screwdriver) how can you get the two new hoses back on!! I'm not a mechanic, so I've only got your basic tools laying around. I don't have a foot long pair of needle nose pliers!!! I might could reach it if I did.LOL!! I know I'm going to get slammed for asking this but that little connecting hose just looks a little hard to get to. Unless you've got the hands of a new born baby. Thanks for clarifying this for me along with any help anyone can give me!!!
1.GOD
2.Family
3.Camaro........& the TENNESSEE VOLS!!!
alyssasdad is offline   Reply With Quote
