JUICEDMOTORSPORTS
Old 05-29-2009, 10:45 PM   #1
hiway61revisted
hiway61revisted's Avatar
Drives: 2010 Camaro & 2000 Silverado
CLEANING CALIPERS
Any thoughts on SPRAYING brake clean on calipers to keep it looking clean
hiway61revisted is offline   Reply With Quote
Old 05-29-2009, 11:03 PM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I'd be worried that it would eat the paint on the rims......
Old 05-29-2009, 11:12 PM   #3
hiway61revisted
ooops your right, painted wheels
Old 05-29-2009, 11:14 PM   #4
Kwaz1335
The Kwaz
Drives: Black 2010 Camaro 2SS/RS
Send a message via AIM to Kwaz1335
If it really becomes a problem...use a light detergent soap and water when washing your car with a toothbrush. If your really anal (like me) pull the wheels off and spray em down real good
Ordered:3/13/09
1100: 3/13/09
3300: 5/12/09
Picked up and brought home 6/26/2009
2010 Black on Black SS/RS Camaro
Silver stripe package
Ground effects package
6 Speed Manual Transmission with Hurst short throw, Magnuson Supercharger, SLP loudmouth 1 kit.
Kwaz1335 is offline   Reply With Quote
Old 05-30-2009, 08:33 PM   #5
Rodrunner
Senior Member
Rodrunner's Avatar
Drives: 2010 SS/RS, '06 350Z
The metallic gold Brembos on my 350Z are clearcoated. Brake cleaner shouldn't harm it one bit, although if cleaned regularly, like Kwaz1335 said, any car wash soap should remove it. It only becomes a problem when left on for a prolonged period of time.
2SS/RS - Black/Black - CGM Rally Stripes - Auto - VIN 10171
Rodrunner is offline   Reply With Quote
Old 05-30-2009, 09:59 PM   #6
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
I'd avoid the brake cleaner routine, not sure what the effects will be over time and with the extreme temps.
I would suggest using one of the spay-on wheel cleaners for alloy wheels. Make sure the brakes are cold, not warm, and dry. Follow instructions, make sure you use a good hard spray when washing it off.
Should be safest thing and it will work.
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Wheel weights on my Camaro's calipers SNOOK Suspension / Brakes / Chassis 680 09-19-2013 02:37 PM
Optional Brembo Calipers Rallyman6 Wheels and Tires Talk Sponsored by The Tire Rack 35 12-31-2011 06:41 PM
Painting the Brembo calipers mondain Wheels and Tires Talk Sponsored by The Tire Rack 7 04-13-2009 11:57 PM
Glossy Black Calipers ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 7 02-17-2009 09:05 AM
Best Cleaning Supplies GoldFire Cosmetics and Lighting Modification Discussions 52 02-06-2009 11:50 AM
