Old 09-10-2012, 10:06 PM   #1
zare6
Drives: 2011 ss ls3
nitto 555r
I changed up my stock tires to the nitto drag radial, anybody have experience with this tire? What is the best way to prepare this tire for maximim traction at the drags? Thanks
zare6 is offline   Reply With Quote
Old 09-10-2012, 10:13 PM   #2
linehand7
Drives: 03 duramax 01impala 2010 2ssrs
in Canada? add studs it will be snowing soon!lol
linehand7 is offline   Reply With Quote
Old 09-10-2012, 10:51 PM   #3
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
Run them at 18-20 psi and do a good burn out, they take a few seconds to get sticky, but don't over do it.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 09-11-2012, 03:28 PM   #4
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I really like them. I run them all year long (daily driver/track tire). When they are new or fairly new, they work suprisingly well in the rain. Just be careful in the rain when they get worn down. They also last a pretty long time.
I make sure to put a fresh set on my car during the rainy season.
At the track, they do pretty well. Tires like the NT05R and MT work better, but they don't make good street tires due to the lack of grooves to evacuate water and they don't last very long if you use them on the street.
So street/strip tire - NT555R is the best choice
primarily strip - NT05R or MT or M&H
Old 09-11-2012, 10:14 PM   #5
zare6
Drives: 2011 ss ls3
thanks will try a small burnout and see. I tried them cold and at 3000rpm they launched ok, took it up to 4000 rpm and they wont hook at all
Old 09-12-2012, 07:50 AM   #6
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
My exp was decent traction at the strip but they did not get me but 4000 miles. That is 8 passes at track with mild burnouts and i am very easy on my car on the street. Can't see new set of tires every oil change so i went with Invos for the street and MT for the track..
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 09-12-2012, 08:56 AM   #7
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Thats not right, I had BFG drag radials on my old car that lastest 12K miles and like a 100 passes, driving hard on the street. Do not run drag radials at normal air pressure or the center section wears out. They need to be under inflated to last, I used to run around 25 psi in mine.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 09-12-2012, 11:07 PM   #8
Jchaluja
Jchaluja's Avatar
Drives: Twin Turbo Camaro
Mine last 10k to 12k with about 40-60 passes.....I don't run low 60 ft times but I do run mid 10's consistently with them. They work great in the street too. I only run this tires b/c I like driving to the track and back without having to change my wheels.
Jchaluja is offline   Reply With Quote
Old 09-12-2012, 11:13 PM   #9
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
would these be good road track tires also?
franknbeans is offline   Reply With Quote
Old 09-13-2012, 12:28 AM   #10
blackflag
blackflag's Avatar
Drives: 2012 2SS 45th
I don't even do a burnout with 20" ET Streets and they dead hook even at 30#
#1 2012 NMCA/LSX Challenge Series
2012 2SS 45th A6
Thanks to our Sponsors:
coldairinductions.com (Cold Air Inductions)
loughengines.com (Mike Lough Race Engines)
granatellimotorsports.com (Granatelli Motorsports)
blackflag is offline   Reply With Quote
Old 09-15-2012, 03:07 PM   #11
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I'm wondering m'self, just threw some on my car I got tired of slowly getting on the gas to go 1.95's.
I ran my Pirellis at 20-22 psi, so I plan to start around there.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 09-18-2012, 10:10 AM   #12
Pro Stock John
Writer
I'm hoping to get up to GLD tonight and see if I can better my 12.7's.
I'm thinking 20 psi cold, long first burnout, and short thereafter. I've run my Pirellis down around there but am not comfortable running them at 18 psi seems pretty low for the sidewall.
On the street they are better than stock tires.
In the past I could get a whole year on a set.
PROJECT HEAVY CHEVY
