B&M Racing
Old 09-13-2012, 03:35 PM   #1
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
ZL1 Catch can bracket
Looking for anyone that has a catch can mounted on their ZL1 where the bracket is not bolted to the radiator. I saw a picture of one bolted to the radiator bolt but that looked like a bad place to mount it. Anyone got a better set up?
tnspd is offline   Reply With Quote
Old 09-13-2012, 03:57 PM   #2
wilmaya
wilmaya's Avatar
Drives: 1970 Chevelle SS396/496
So far all that I have seen are mounted the same way. Moroso's unit which isn't available yet, is mounted the same way. The extractor doesn't help the situation.
ZL1 PZVSH2 VIN #428 02/24/12
Official Delivery Date 04/18/2012
GAZ-Summit White
MN6, B92, RTQ, WBP
Russell Chevrolet, AR
11/15/11, 1100
01/13/12, 2030
01/30/12, 2000
01/31/12, 3000
02/02/12, 3300
02/11/12, 3100
02/20/12, 3400
wilmaya is offline   Reply With Quote
Old 09-13-2012, 06:18 PM   #3
SC2150
No issues with the current mounts yet and have sold/installed dozens. The dual valve system we released is the only one I'm aware of that traps all the oil and deals with the design of the new GM blower applications. Check w/Elite also, Steve may have a different bracket solution, but it mounts secure and makes use of the space well.
And if your considering any other than the ones tested to not allow a ton of oil to pull through, I suggest doing so. Very easy and you will be amazed how some well known brands let nearly as much through as they trap. The Elite, Mike Norris, AMW, Saikou Micchi (all direct competitors of our design) ALL let a fraction through and trap nearly all compared to most.
Old 09-13-2012, 10:36 PM   #4
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
Mounting it on the radiator is solid. I was skeptical but it is as solid as can be.
jimmy5 is offline   Reply With Quote
