SDTW Custom Wheels & Tires
Old 09-13-2012, 10:14 PM   #1
pluckracin
pluckracin's Avatar
Drives: 2012 zl1
oil catch tank
i bought this cool carbon fiber oil catch tank with a window in it..
pluckracin is offline   Reply With Quote
Old 09-14-2012, 12:16 AM   #2
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
I like that! How much?
sammyv is offline   Reply With Quote
Old 09-14-2012, 06:02 PM   #3
pluckracin
pluckracin's Avatar
Drives: 2012 zl1
oil catch tank
sammyv i got this from fastwrx.com in va. 75.00 + 8.00 shipping, i like the sight glass in it for easy view of oil level and the carbon fiber also. best deal i have found to date. this goes great with my carbon fiber intake tube as well. thanks mark
Old 09-14-2012, 06:42 PM   #4
SC2150
It is an empty liquid overflow tank....does not separate oil from the crankcase vapors. Would work great as a radiator overflow, etc. but its just an empty can w/fittings on it....not an oil sperator. Looks nice though!
Old 09-15-2012, 09:56 AM   #5
LWM
LWM's Avatar
Drives: #54 ZL 550 CGM Camaro 2SS/RS,GIF
Had the oil catch can installed at Fest II ......typically I have emptied about separated oil from the catch can about every 3000 miles. Usually the catch can is 1/4 full.....just saying!
LWM is offline   Reply With Quote
Old 09-15-2012, 12:55 PM   #6
pluckracin
pluckracin's Avatar
Drives: 2012 zl1
works well
yeah this oil catch can has a separator plate with a down tube thru the center and a stainless screen below that, the subaru race guys use this and it works great, two sight glasses to watch it work...
Old 09-15-2012, 01:29 PM   #7
snapp32e
snapp32e's Avatar
Drives: '81-Z28/'07-Tundra/'12-ZL1/'13-Jeep
Does it come with some sort of mounting hardware?
ZL1 #612
snapp32e is offline   Reply With Quote
Old 09-15-2012, 01:48 PM   #8
SC2150
LOL! No intention of insulting you....just sharing info as you paid a premium to have a car as awesome as a ZL1. Tell you what....test it for yourself. spend $8-10 for a clear glass inline fuel filter and install it between your intake manifold and the can outlet and watch how much oil this can lets past. It looks great, and even a beer can with 2 fittings in (yes, we tested that as a joke and were surprised how much oil it caught) will catch oil...any container that allows cooling will condense some of the oil out of the crankcase vapors.....but the idea, especially with a DI motor is to trap ALL the oil, not just a small portion of it. All I'm doing is sharing with you the functions and how to test for yourself. Dont take my word for any of it (yes, we have that same can disected in house on display with the other dozen or so we test).....do it and see for yourself.
It is far better than no can at all so your helpping a portion of the issue, but you want no oil in your intake air charge. Especially with a ZL1 as you want no oil residue build up on your blower rotors as over time the build up throws the balance off....and then the intercooler is mounted below the blower and this si what happens to it in short order as the oil bakes on the fins, etc:
Old 09-15-2012, 02:02 PM   #9
pluckracin
pluckracin's Avatar
Drives: 2012 zl1
yes
comes with clamps + hose,mount clamp with rubber liner, bracket w/bolts
Old 09-15-2012, 07:15 PM   #10
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Like he said anything with catch oil but unless its a true good separating can some oil will still go past, I made this for my 85 MK1 VW GTI because it fit the theme of the car it cought oil but let alot pass threw but it looked awesome in the bay
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 09-15-2012, 07:20 PM   #11
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 09-15-2012, 07:33 PM   #12
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
The guys at rx have a superior design, the inlet goes down into the last quarter of the can with a few holes along the way into a medium that helps trap and collect the oil vapor, so it is properly filtered before the air hits the outlet, which is much higher meaning it can't suck in the oil vapors from the inlet.
It's a simple design, but effective. If you just have an inlet and an outlet, which are at an even level then most of the oil vapor is going to get sucked back in. Sure it will catch a little, but not nearly what a can with a filtering medium and staggered inlet and outlet tubes will do.
jimmy5 is offline   Reply With Quote
Old 09-19-2012, 11:54 AM   #13
SC2150
OK, I ordered one of the wrx cans...and it arrived. Didnt spend the extra for the hydro coat finish as after we test these we cut them apart to show the inner workings.
Here is the diagram:
It is just a made it china can that the majority of the vapors come in the ceter tube and right out the outlet as you can see. The screen in the center is below the inlet tube so it does nothing. This is no different in function than the orange juice bottle shown but does look great.
Below is a picture to show how the oil is separating in a properly functiong can.
You guys have spent the $ for a king of the camaros ZL1, but have put a can on the allows as much or more oil through and still into the intake tan it traps, so you will still have the same issues....just a little later as you are trapping some of the oil.
Remeber, its not the oil you capture...its what still passes through and with these cheap cans that are really nothing more than an empty can w/2 fittings in let more through than they catch:
Look close at this picture, (these are the parts before final assy and finishing so you can see just what is needed to separate and trap the oil from the crankcase vapors) The vapors enter the center of the can, then they travel down the inlet tube which passes through the separate outlet chamber so no vapors are mixed with the exiting vapors that have already had the oil separated and trapped. Then as the tube passes into the seaparate coalescing chamber, it is dispersed into a coalesing media that traps nearly all the oil which then drips out drains in the bottom of the coalesing chamber into the condesing and colletion chamber (all of these now are totally separate form all other as this is a complex process and you cannot allow the incoming and outgoing vapors to ever comingle or the process is compromised).
Then the vapors are cooled in the condesing chamber and any oil still in suspension is then condensed to droplets that fall out of supension as the vapors are drawn up the outer (cooling surface) wall of the can evenly and into the separate outlet chamber where there are integrated flow controlling check valves that prevent any reversion at WOT from pushing vapors backwards through the can.
This is the most effective and robust design in the industry period aside from going to the $8-$12k centrifuge style Alfa Laval uniits used on industrial diesel applications.
The industry is full of empty, or near empty cans called "oil catchcan" and sold as separating cans.......and this is so confusing to those that are not knowledgable on the function and purpose for them.
There are several other cans that work great trapping most of the oil but none with the engineering you see in the pictures above.
The ones we have tested in depth and disected are (in order of effectiveness, and they all work very well):
RX Products
Saikou Micchi
Elite Engineering
AMW
Maike Norris/CCA.
These, and only these worked well enough to be reccomended by us and we have tested most every one on the market (as any that have visited our facility in person and seen the collection on display) and there are some that cost over $200 and look awesome ....and some with some of the biggest names in the performance industry let nearly as much through as they trap....it is all in understanding the issue, the function, and the process for actually effectively separating the oil vapor/mist from the crankcase vapors and most you see for sale are companies jumping on the bandwagon to just sell a product.
Hope this helps those wanting to fully understand this.
Old 09-19-2012, 03:03 PM   #14
snapp32e
snapp32e's Avatar
Must be the "Robber" strip that gives the WRX can it's high end performance.
ZL1 #612
