sjm autoprod
Old 09-19-2012, 12:30 AM   #29
DMC1805
DMC1805's Avatar
Drives: 2012 Camaro 2SS RS
Originally Posted by christianmotox View Post
Dude you made a lot of progresss, I've been working on mine for a couple of months. Lol
Yours is turning out great
Thanks! I appreciate it. I hope I can finish up this weekend.
I gather my energy by feeding on the life-force of children.
DMC1805 is offline   Reply With Quote
Old 09-19-2012, 12:50 AM   #30
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Me too, I'm also doing my rear diffuser, I already did the a pillars and some mouldings
christianmotox is offline   Reply With Quote
Old 09-21-2012, 03:08 PM   #31
camarostar2010
Drives: 2011 SS
I want to thank the Op for his help and guidance on my cf project. Hats off to you. When I do mine cf job I will also post
camarostar2010 is offline   Reply With Quote
Old 09-21-2012, 03:10 PM   #32
DMC1805
DMC1805's Avatar
No prob bud. I'll be posting more tonight and hope to finish this this weekend.
Old 09-21-2012, 03:13 PM   #33
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
OP is awesome. i have asked a ton of questions and he was kind enough not to send me to hell lol. i plan to do my own DIY when i buy the materials.
Old 09-22-2012, 01:55 AM   #34
DMC1805
DMC1805's Avatar
Here we are now, weekend three of my carbon fiber project. I spent a lot of time sanding the parts and they still weren't good enough for clear coat, so I added two more layers of epoxy.
I have gotten several PM's regarding this project asking about what materials are needed. This first picture is of the epoxy that I use and other accessories. I use just a cheap paint brush, paper cups to mix the epoxy in, a popsicle stick to stir the epoxy, and a gram scale that I confiscated off of some criminal.
Now on with adding the epoxy.
I taped off the sides of the parts that I didn't want to add epoxy to. I did this to make it a bit easier to clean those areas, as if I did not tape it off, I would have to grind down or sand the edges all over again and I spent several hours sanding last weekend.
Once all of the pieces were masked, I laid it all out and began to measuer out the epoxy. I first measured out the resin, then it in half and added that amount of harder. As you see in the next pic, I poured out about 72 grams of resin so I would add 36 grams of hardener to that for a total weight of 108 grams.
Size:  184.7 KBName:  IMG_1017.jpg
Size:  156.3 KBName:  IMG_1018.jpg
Size:  162.8 KBName:  IMG_1019.jpg
Size:  198.8 KBName:  IMG_1020.jpg
Size:  217.0 KBName:  IMG_1022.jpg
Next I brushed on the epoxy. I put on a pretty thick coat and was having trouble with a lot of bubbles. I think it would be better to use thinner coats, but I am planning to wet sand the parts again before I clear coat, so I'm not terribly worried about the dimples from the popped bubbles. Now here are the parts after the two layers of epoxy. I will now let them cure overnight and tomorrow I will sand them with 800 grit sandpaper in preparation for clear coat. I then hope to clear coat on Sunday!
Size:  215.2 KBName:  IMG_1025.jpg
Size:  102.0 KBName:  IMG_1026.jpg
Size:  192.7 KBName:  IMG_1027.jpg
Size:  176.4 KBName:  IMG_1029.jpg
Size:  217.7 KBName:  IMG_1030.jpg
Size:  238.5 KBName:  IMG_1031.jpg
Again if anybody has any questions just ask and I will try to answer it the best that I can.
Old 09-22-2012, 02:14 AM   #35
camarostar2010
Drives: 2011 SS
Hi..i already started working on mine...to remove bubble us a good heat gun. Just be careful not to get too close or stay in one spot too long. this can actually burn or sizzle the resin. I been using that technique for bubbles with great success Pics coming soon.
Old 09-22-2012, 02:29 AM   #36
DMC1805
DMC1805's Avatar
Cool thanks man. I was just using a hair dryer.
Old 09-22-2012, 08:02 AM   #37
Ringo
Politically incorrect
Ringo's Avatar
Drives: 2SS/RS
Looking good. Why 800 grit sandpaper? That's pretty fine. Your resin looks iike its pretty thick, wouldn't a wet sanding of 320/400 first to flatten it out then the 800 get things smooth faster?
2SS/RS M6 IO interior. Built 8/14/09. Delivered 9/9/09.
Ringo is offline   Reply With Quote
Old 09-22-2012, 02:51 PM   #38
DMC1805
DMC1805's Avatar
If you need to cut through some high spots you can certainly use a lower grit sandpaper, then finish with 800 before you clearcoat.
Old 09-22-2012, 03:45 PM   #39
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
I should have never read this. You're doing such a great job detailing this out....now I want to try it.
Where did you buy your material?
awfarley is offline   Reply With Quote
Old 09-22-2012, 05:19 PM   #40
DMC1805
DMC1805's Avatar
Cjcompositestechnology.com
Old 09-23-2012, 12:48 AM   #41
DMC1805
DMC1805's Avatar
I sanded down the smaller pieces and decided to go ahead and clear them now (I am inpatient and want to see how well they were going to turn out).
I'm sure the suspense is killing you.
Size:  231.2 KBName:  ImageUploadedByTapatalk1348375659.211250.jpg
That's all for now. I'll start on the door panels tomorrow. I'm going to the bar!
Old 09-23-2012, 04:21 AM   #42
Ringo
Ringo's Avatar
Drives: 2SS/RS
Looks really good! The door inserts will be eye catching once they are done as well. True carbon fiber and a good clear coat have a luster to them I really like. Once you've seen it, hydro-carbon will never be an option. My console insert is here, just waiting on the cf cloth and resin.
