Jason 98 TA
Old 05-30-2009, 06:13 PM   #1
H3LLJumper
H3LLJumper's Avatar
Drives: 2010 Camaro 2SS VIN#11184
Aftermarket built in all-in-one GPS, audio, etc?
Anyone know of any aftermarket GPS/Radio/CD/Etc that you can put in to the dash to replace the current radio? Do any fit without having to replace all of the wiring? Thanks!
H3LLJumper is offline   Reply With Quote
Old 05-30-2009, 06:16 PM   #2
Road_Warrior85
Drives: IBM 2SSRS, 12 Jeep Wrangler 4door
Send a message via Yahoo to Road_Warrior85
Have you seen inside a camaro????
Just the shape alone (not to mention how it all ties in to the computerized everything goin on in there) tells me that there is no way you can replace it.
Hell, all the AC/Heat settings are built into it.
Road_Warrior85 is offline   Reply With Quote
Old 05-30-2009, 06:16 PM   #3
Silverghost
Silverghost's Avatar
Drives: Z28
Good luck with that, the radio is integrated with the car and works some of the non-radio related functions.
Speed Kills - Drive a Ford and live forever!
www.rivercityperformance.com
Silverghost is offline   Reply With Quote
Old 05-30-2009, 06:18 PM   #4
H3LLJumper
H3LLJumper's Avatar
So it's going to (at least for a year or more..) for a built in GPS system?
Old 05-30-2009, 06:44 PM   #5
Pyottboy
Drives: Black 2SS/RS
get a custom dash built to house the head unit that would do audio/video/gps/back up camera and then have them wire everything so all previous functions would still work. it would take a LOT of time and a good amount of money but it definitely would be worth it in the end. this is something that im going to look into when I get my camaro. perhaps you could head over to an aftermarket audio shop and have them take a look at your car and maybe they can help you. the only way to know for sure if it can be done is to ask the experts
Black 2SS/RS 6A
Vararam/Ported TB/ARH LTs/Loudmouth 2/Dyno tuned
BMR sways/full bushings/trailing arms and toe rods/dropped an inch
Interior/exterior accents that make the car bangin
Pyottboy is offline   Reply With Quote
Old 05-30-2009, 08:12 PM   #6
H3LLJumper
H3LLJumper's Avatar
If only some good ones existed in my neck of the woods.
Old 05-30-2009, 08:15 PM   #7
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
I don't see it as worth it.. Buy yourself a top of the line Garmin GPS, an Ipod Touch to put your music on and you're set...
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 05-30-2009, 08:49 PM   #8
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
It'd probably take a LOT of money and the services of a very good electronics engineer to bodge something together that utilizes the existing non-music related functions of the existing hardware, as well as integrate the equipment you'd like to add. Very custom. Probably do-able, but $$$$$
patriotpa is offline   Reply With Quote
Old 05-30-2009, 08:54 PM   #9
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Why buy an iPod if you're just going to use it for the car? A USB thumb drive will do the same trick for a much smaller cost.
UCF w00t is offline   Reply With Quote
Old 05-31-2009, 01:17 AM   #10
H3LLJumper
H3LLJumper's Avatar
If I wanted to do that, I wouldn't have made this post. Eh?
Old 06-01-2009, 02:21 AM   #11
H3LLJumper
H3LLJumper's Avatar
Well, if anyone gets some info, post it here!
Old 06-02-2009, 01:53 PM   #12
TomServo
Drives: 2007 Z06
GM screwed the pooch on this, why such a proprietary design is beyond me. It’s going to cost a ton of $$$ to install any aftermarket system.
And its not like they had a space limitation to worry about.
TomServo is offline   Reply With Quote
Old 06-03-2009, 03:02 PM   #13
drummerstevey
drummerstevey's Avatar
Drives: 2006 VW GTI
if there is a way to do it, put in one of the kenwood systems, they have garmin gps systems in them, with traffic updates too
Good things are worth waiting for...
drummerstevey is offline   Reply With Quote
Old 06-03-2009, 03:23 PM   #14
jparra2121
Drives: GMC Yukon
This is the only system that I've seen that works with the existing interior:
http://www.navigadget.com/index.php/...ar-view-mirror
jparra2121 is offline   Reply With Quote
