Old 09-15-2012, 02:30 PM   #1
firecross91
firecross91's Avatar
Drives: ZL1 #1691 Black on black.
Brake upgrade questions
Guys I need some help. Plan to track my ZL1 and have a couple questions. Does anybody make a replacement drilled rotor that bolts to the factory hat? Do I need to order a stainless brake line kit or are the stock lines good enough. Lastly do I need to change my brake fluid? And is stock fluid type good for this?
firecross91 is offline   Reply With Quote
Old 09-15-2012, 02:45 PM   #2
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
If you're going to track your ZL1 I would change the fluid regardless to up the boiling point while you're at it. Might as well, you're going to be in there changing things regardless, and it's not that hard to do either. That'll make sure that everything you get works together so that you can decrease the brake fade.
ModBargains.com is offline   Reply With Quote
