JDP Motorsports
Old 09-15-2012, 11:01 PM   #1
Bad Dad
Bad Dad's Avatar
Drives: 2010 2SS/RS , 2011 C6 Base Corvette
Question 9" Ford DSS what center section NHRA
What Center section / Diff Meets the NHRA no C-Clip Rule ?
SUICIDE BY RACECAR
Bad Dad is offline   Reply With Quote
Old 09-16-2012, 12:11 AM   #2
Bad Dad
Bad Dad's Avatar
Question NHRA C CLIP RULE
OR does that apply to a IRS setup
SUICIDE BY RACECAR
Old 09-16-2012, 08:44 AM   #3
flyby
Drives: 2010 Silver SS
Don't know for sure but I got a strange 3:73 heavy duty center section and have never been asked about "c clips".
flyby is offline   Reply With Quote
Old 09-16-2012, 08:52 AM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
As far as i know, no clips on irs
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 09-16-2012, 02:05 PM   #5
Bad Dad
Bad Dad's Avatar
C Clips
Talked with Diet Coke today he says rule does not apply since the axel is bolted in with the large nut on end at the rotor mounting assm.
SUICIDE BY RACECAR
Old 09-16-2012, 02:51 PM   #6
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
The c clip issue pertains to the axles not being physically located only by C clips. Obviously this could create an issue if the c clip failed, in the case of a solid axle you'd have the wheel/tire/rotor etc go flying off worst case, since the axles literally slide right out of the hubs.
In our case, the axles are physically secured with the axle nut, which is why the c-clip rule doesn't apply, as it only stipulates that axles must not be SECURED by c-clips, not that axles cannot have them at all.
pouncer72 is offline   Reply With Quote
Old 09-16-2012, 05:16 PM   #7
Bad Dad
Bad Dad's Avatar
Cool C Clips
Exactly what DC said thanks for te claification im happy... also got my RPM rollbar stuffed in today remember the A pillar has to screws it doesnt just pull off....
Thanks
SUICIDE BY RACECAR
