Old 05-31-2009, 01:06 AM   #1
roadie2991
Camaroholic
roadie2991's Avatar
Drives: '10 Camaro 2LT/RS IOM int/ext
Minor Problem With My Window Indexing
I had a relatively minor problem with my window indexing this evening and I thought I would share what I learned from this. As my wife and I were leaving a party, I noticed "Open, Then Close Passenger Window" displayed on the DIC. I was aware that if your battery was disconnected...then you had to do this to reprogram the window indexing. However, my battery had not been disconnected. So, when I tried to lower the window...it would not open at all. I pulled over and walked around to the passenger side...opened the door. The window did not index as it is supposed to. As I gently attempted to close the door, the glass blocked it from closing. At this point I decided to consult the owner's manual. On page 1-15, I found this "If the vehicle loses power or the window freezes, this feature (window indexing) may not work. From outside the vehicle, close the door and push the window inward so that the glass goes under the molding". In actuality, you must gently push the door closed until you get resistance on the window, then apply pressure to the very top of the glass until it slides under the molding...then push the door until it latches. When I got back in, the warning was still on the DIC and the window still would not lower. So I drove to my next destination, turned off the engine....and restarted it....still nothing! So then I turn it off again....waited about 3 minutes...started it and the window then worked (but not the express open). I lowered the window all the way and then back up. I checked the window indexing and express open...still nothing. I then lowered the window all the way down....waited a few seconds, then raised it back up. At that point the express open and window indexing began functioning normally again.
I certainly don't want this thread to become a "what kind of crap are they putting out" discussion. Let me be clear...I love this car and it was only a minor inconvenience. Now that I know what to do should it ever happen again, this it will be even less of an inconvenience. I just wanted to pass this information on, in case it ever happens to any of you...to save you a little time.
Ordered 10-13-08
1100 10-15-08
2000 3-19-09
2500 3-24-09
3000 3-26-09
3100 4-18-09
3300 4-18-09
3400 4-30-09
3800 5-6-09 #8102
4000 5-6-09
4104 5-6-09
4B00 5-6-09
4200 5-12-09
5000 5-20-09
6000 5-20-09
roadie2991 is offline   Reply With Quote
Old 05-31-2009, 01:10 AM   #2
Vash
Drives: 00 Blazer
Take it to the shop. There was some kind of similar issue with the CTF that they fixed I think. They might be able to fix it by reprogramming or reflashing the main controller.
But the dealer has the tools for that so.
Good Luck on it, no biggie it will get fixed.
Old 05-31-2009, 01:13 AM   #3
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
Drives: 2010 SS/RS IOM 2014 2LT Stingray
OMG EVERYONE PANIC!!!!!!!!!!!!!!!!!!!!!!! Then again lets not. If it continues to be a problem, then I'm sure some software engineers will be on it. How about we just wait and see and if its a problem, wait on the fix and then go get the fix. Or we can all just FREAK THE F*&# OUT!!!!!!!!!!!!!!!!! Can we do a poll on whether to freak out or not?
BTW, thanks for the info. Hopefully it will not continue and if so, an easy and quick fix.
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Jamie Mac is offline   Reply With Quote
Old 05-31-2009, 01:14 AM   #4
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
thanks for the heads up
2010 2SS/RS, OBX l/t headers, with high flow cats, MBRP full 3" exhaust, modified air intake (CAI), Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidampr 25% upd, MGR shifter, VTC, and tune by Jannetty Racing. MRR M228 rims, phantom grill, vinyl wrapped hood and rear spoiler.
tbss1 is offline   Reply With Quote
Old 05-31-2009, 01:15 AM   #5
FiLTHy PHiL SS/RS
Me likes Blue
FiLTHy PHiL SS/RS's Avatar
Drives: 1968 Camaro RS, 2010 SS/RS IBM
I know on my 02 vet there is a code sequence through the dash functions to set how hard the windows go up and down. there is no indexing on my vet.
but my 05 stang has it. and i set that by holding down all the way and hold a few secs, sets down. same for up all way hold few secs and its indexed.
Hope that helps a little as well.
hated to use mustang example... sorry
Ordered 4/25/09 Born on 6/11/09 Delivered 6/26 Picked up 6/27
2SS/RS IBM, Body Matched Ground Effects, Sunroof, Silver riser stripes, ADM CAI, Noweeds exhaust, Catch Can (Blue).
Don't care what color. as long as it's Imperial Blue Metalic!
Own 68 Camaro RS 327 LeMans Blue, 2002 Vet Electron Blue
FiLTHy PHiL SS/RS is offline   Reply With Quote
Old 05-31-2009, 11:27 AM   #6
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
I had a glitch with mine...
drivers side window would not go up fully. Tried a few times then it worked ok. Haven't had problems since then.
Chalking it up to just one of those things. As you probably saw on page 1-16 of the owners manual how to re-program the indexing. If I have problems again, I'll try that. If it continues I'll see the dealer. I really don't want anyone removing the the door panel if I can avoid it.
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Old 05-31-2009, 11:34 AM   #7
Number_9
Number_9's Avatar
Drives: 2010 2SS/RS L99
Originally Posted by KJS View Post
...As you probably saw on page 1-16 of the owners manual how to re-program the indexing...
Seriously, sixteen pages to explain reprogramming the window indexing? Wow.
Number_9 is offline   Reply With Quote
Old 05-31-2009, 12:02 PM   #8
bballr4567
Drives: 2016 Camaro 1LT M6
No. GM uses certain sections to explain stuff. Section 1 is usually the stuff you can program or change. I think section 4 is the safety stuff and section 6 is the mechanical information.
Window indexing is in section 1 and on page 16 in THAT section. They restart the page numbers over again in each section.
bballr4567 is offline   Reply With Quote
Old 05-31-2009, 12:05 PM   #9
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Not pages "1 through 16" but "section 1 page 16"
UCF w00t is offline   Reply With Quote
Old 05-31-2009, 12:09 PM   #10
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
WOW, what kind of crap is GM putting out! j/k ::
Old 05-31-2009, 12:16 PM   #11
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
You're the only one so far who is panicking..lol..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 05-31-2009, 12:29 PM   #12
Number_9
Number_9's Avatar
Sorry, forgot to add a LOL or something to the end, to indicate I was kidding.
Old 05-31-2009, 12:31 PM   #13
Emher
Pillaging Viking
Emher's Avatar
Drives: Saab 9-5 '99 (Hey it's a GM!)
Send a message via MSN to Emher Send a message via Yahoo to Emher Send a message via Skype™ to Emher
Irony and sarcasm is apparantly hard to understand on the Internet.
"Fifty years from now, when you're looking back at your life, don't you want to be able to say you had the guts to get in the car?"
Emher is offline   Reply With Quote
Old 05-31-2009, 12:34 PM   #14
bballr4567
HAHAHAH Its all good. I figured you were but some people dont pick up on it so might as well give an explantion of GMs stupid manual listings.
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 09:57 PM
R6P-If Window Stckr shows price increases-How do u get dealer 2 honor org MSRP price? renderinfo Camaro Price | Ordering | Tracking | Dealers Discussions 48 06-03-2009 12:03 PM
window indexing for tinting cm5217 Cosmetics and Lighting Modification Discussions 34 06-01-2009 07:38 PM
Skip shift, window indexing, & car starting videos Embalmer Camaro Photos | Spyshots | Video | Media Gallery 25 05-10-2009 01:17 PM
Some accessories can be listed on your window sticker. jjy59 Camaro Price | Ordering | Tracking | Dealers Discussions 12 03-23-2009 11:33 AM
