Cold Air Inductions
Old 09-18-2012, 05:54 PM   #1
Lucas Camaro
Lucas Camaro's Avatar
Drives: 2010 Camaro SS
Ahh man...not another LIGHTING question..
Yes, I have a lighting question.
Just know that I have researched this matter and unfortunately can't seem to find straight answers- I will admit I don't know too much about lighting.
If you guys could help me out I would really appreciate it!
I have a 2010 2SS (Non- RS)
I recently purchased CG headlights.
While they are decently bright, I was hoping to maybe get a different color (either 5000k or 6000k). I would also like my fog lights to be matching for the mean time but I will probably be getting a ZL1 front fascia. ZL1 fogs are 4300k right??
What exactly will I need to buy for my headlights and for my fogs? And if I buy a kit for my fogs can I eventually transfer that to the ZL1 fascia? I have been considering a kit on DDM
ANY and ALL help is appreciated!
Lucas Camaro is offline   Reply With Quote
Old 09-20-2012, 03:35 AM   #2
Lucas Camaro
Help!
Old 09-20-2012, 03:42 AM   #3
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
CG headlights?
Old 09-20-2012, 04:01 AM   #4
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Originally Posted by lscamaro View Post
CG headlights?
http://www.cgdistribution.com/prods/...CO10PBCRF.html
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 10-22-2012, 03:21 AM   #5
Lucas Camaro
bump
Old 10-22-2012, 03:45 AM   #6
SummoneR
Paul
SummoneR's Avatar
From what I understand the larger of the two lights are the same as the DRL's on the RS model a P13W build at around 5000k? I believe. They dont look as yellow as 4300k to me... but anyway if you get the AAC Plasma DRL's they are closer to 7000k/8000k Or you can get the regular LED P13W's they are closer to 5000k/6000k range I believe. As far as the projector lamp in the ZL1 fascia it has a replaceable bulb as well, just get a bulb that matches the headlights color you settle on.
Old 08-14-2013, 02:50 PM   #7
Lucas Camaro
Thank you.
Is there anyone else that uses CG headlights??
Old 08-14-2013, 03:11 PM   #8
CamaroI
Drives: 2010 IOM Camaro
Call Gen5DIY they will be able to help
CamaroI is offline   Reply With Quote
bulb, fog lights, headlight, hid, lighting
