BORLA
Old 09-18-2012, 09:40 PM   #1
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
Inter cooler pump
How can you make the inter-cooler pump run when the car is off, after a drag run. I want to try icing the super charger down but wont I need to have the pump running to chill the inter-cooler also?
tnspd is offline   Reply With Quote
Old 09-18-2012, 10:48 PM   #2
KD Innovations
Drives: 2012 ZL1, 2009 CTS-V
In the tune, engine/torque management/supercharger/ERT min = 0
KD Innovations is offline   Reply With Quote
Old 09-19-2012, 07:22 AM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
It would be nice to have a simple switch under the hood.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 09-19-2012, 09:15 AM   #4
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
When I upgraded my pump, I wired in a switch. There are 3 wires going into the pump. If I remember correctly, wire 4 is brown and is the hot wire. I ran a wire from it up to a switch I put on the bracket under the fuse box. For the hot lead, I hooked to the "bolt" on the front of the fuse box. Always put a fuse inline. I also have the stock fans wired to come on. On low.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 09-19-2012, 09:22 AM   #5
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
I pulled the relay and inserted a wire and ground it out (HILLBILLY RACING) in between rounds . Not the smartest idea but it worked
tpower is offline   Reply With Quote
Old 09-19-2012, 09:22 AM   #6
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
Mine stays running when the key is turned to the on position. I have to say the eforce is perfect for a block of ice to sit on
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 10-28-2012, 12:10 AM   #7
VEGASLSX1
Drives: Camaro RSSS
What HX tank do you have?
VEGASLSX1 is offline   Reply With Quote
Old 10-28-2012, 08:45 AM   #8
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
LPE installed a switch on my car with a timer! They should be selling them soon! Call and ask for Tim Dyer!
sammyv is offline   Reply With Quote
Old 10-28-2012, 09:05 AM   #9
KD Innovations
It's free, in the tune.
