sjm autoprod
Old 09-20-2012, 09:20 AM   #1
petetcs
Drives: 2013 ZL1 victory red
mild to wild
anyone put a mild to wild switch on your z if so any problems
petetcs is offline   Reply With Quote
Old 09-20-2012, 09:56 AM   #2
JWR046
JWR046's Avatar
Drives: 2012 ZL1 #1786
There is a bunch of us that installed it. Works great. Funny I never closed the baffle yet since I installed it. I thought the drone would be too loud on the highway but actually it is not bad at all.
There is a good thread here.
http://www.camaro5.com/forums/showthread.php?t=245093
JWR046 is offline   Reply With Quote
Old 09-20-2012, 09:58 AM   #3
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
I agree, the drone isn't bad. I had long tubes and straight pipes on my 4th gen SS, now that was drone! No problems with my m2w.
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 09-20-2012, 10:07 AM   #4
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Unlike the Vette... There is really not much of a difference on the Z since it's open at idle and a lot of other times as well. Just introduces a little drone on the highway. Not worth $89 IMHO.
Old 09-20-2012, 12:03 PM   #5
hognutz
hognutz's Avatar
Drives: 2013 ZL1
see my post in the DIY $25 is all it cost to add it. I am not sure it is worth it stock. I did it becaseu i am going to add headers and that may introduce more drone at somepoint.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 09-20-2012, 12:13 PM   #6
GoldenBear
Bear Backer
GoldenBear's Avatar
Drives: 69 Camaro Z/28, 69 Corvette Conv
If you're never planning on closing the baffle, then you can simple pull the fuse which will leave the baffle open all of the time and save the $89.
Current Chevrolets: 1969 Camaro Z/28 -- 1969 427/390 Corvette Convertible -- 1970 350/300 Corvette Convertible -- 2013 Camaro ZL1 Convertible -- CRT / Exposed CF Weave Hood Insert / Suede Package / Polished Wheels / MN6
GoldenBear is offline   Reply With Quote
Old 09-20-2012, 12:14 PM   #7
mlee
www.CamaroFest7.com
mlee's Avatar
Yup... my total cost was $20. Have it programmed into my Homelink buttons so no need for remotes.
Old 09-20-2012, 12:16 PM   #8
Louder the Better
Old 09-20-2012, 12:26 PM   #9
mlee
www.CamaroFest7.com
mlee's Avatar
Louder the Better
Then with this car you're going to want headers... Pulling the Fuse doesn't really do that much.
Old 09-20-2012, 02:05 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
one more though I had if money is more an issue for people than labor you can use that same fuse tap to a toggle switch if you are will to run wires up to the consol.
I used the remote setup that MLEE pointed me too because I just did not feel like running the wires for the $13 it cost to buy the unit.
there is also a way to do a three position switch to force the flapps closed once you have headers or exhaust mods to give you 3 stages of sound so to speak wich I may do once I istall the headers if I decide to go catless.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 09-20-2012, 02:18 PM   #11
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
Just pull the fuse. Free mod.
jimmy5 is offline   Reply With Quote
Old 09-20-2012, 02:28 PM   #12
Godsplumber
Godsplumber's Avatar
Drives: 2012 ZL1,Victory Red
Works great, and better than pulling fuse, because on a long drive you might want to turn off the drone, cause it is there. Just not too bad.
Godsplumber is offline   Reply With Quote
Old 09-20-2012, 02:38 PM   #13
JWR046
JWR046's Avatar
Exactly my thought. I just wanted the option to close it on the highway. I agree pulling the fuse will work but $89 on a $60k car is not a big deal. The way gas is going it is about a tank of gas. :(
On a second note I am pretty pleased with the exhaust sound of the car. It is loud enough without being annoying and has a good rumble.
Old 09-20-2012, 04:29 PM   #14
Z4me
Z4me's Avatar
Drives: 2013 ZL1 IOM Vin #169
Ok you have my attention on this one. I had headers and a cam done to my ZL1 and it sounds great, but I would also like to be able to tone it down some in the neighborhood, or when I want to hear the music in the car. Can you send me a pm about this three position switch, for the mild to wild unit. I was thinking of purchasing the unit with the hopes of it having that ablilty, thanx.
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=36987&dateline=1334886195 border=0 alt= />
Z4me is offline   Reply With Quote
