JUICEDMOTORSPORTS
Old 10-03-2012, 12:16 PM   #71
Jonathan@AACstyle.com
Jonathan@AACstyle.com's Avatar
Drives: www.CamaroLighting.com
Originally Posted by FRANK121 View Post
Jonathan, Thanks for all your help
Got mine installed last night and it looks awesome! But for some reason my remote is acting up occasionally? ( I tried a new battery with same results )
It may work from 30 feet away one time and then the next time it won't work until I'm 2 feet away?
I also have not been able to turn on and off from inside the vehicle?
I installed the remote box for the unit next to the fuse box under the hood.
Do you know a way to wire up the unit so it will scan when the doors are locked and or unlocked, Plus be able to use the remote as usual ?
Again, thanks for your time!
The new scanner uses a IR eye so you will not be able to control the scanner unless you are pointing the remote at the eye in the center of the scanner but from what you are stating it sounds like you ordered the universal 22" scanner?
I do not know a way to wire the scanner for those functions but someone on here may be able to assist you with that wiring.
Jonathan@AACstyle.com is offline   Reply With Quote
Old 10-03-2012, 12:17 PM   #72
AACstyle
AACstyle's Avatar
The Remote is IR or Line-of-Sight (like your TV remote) you have to point it directly at the sensor in the center of the scanner.
AACstyle is offline   Reply With Quote
Old 10-03-2012, 12:35 PM   #73
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
Jonathan, thanks for the info about cutting the wires will not void the warranty. Going to install it in just a bit. Hardest part is going to be putting the radiator cover back in place.
Haole is offline   Reply With Quote
Old 10-03-2012, 12:52 PM   #74
I look forward to seeing the scanner installed.
Old 10-03-2012, 01:43 PM   #75
FRANK121
FRANK121's Avatar
Drives: 2011 Camaro SS
IR eye, that makes sense now. I may have to wire up a switch inside then? I want to be able to turn them on and off from the drivers seat and use the remote to only adjust the patterns. I think an on off switch in line with the power wire may do this?
2011 Victory Red 2SS/RS
630hp. and 550ft. lbs.
Black Rally Stripes
6 Speed Automatic
Whipple 2.9L
LS3 Conversion
ARH LT Headers and X-Pipe
GMMP Axle Backs
Yank 2800 Stall
RotoFab CAI
RX Performance Catch Can
VMAX Ported Throttle Body
Built by C.B.I. Streetcars
Tuned By DSX Tuning
GM Quarter Flares
Camaro Floor Mats
FRANK121 is offline   Reply With Quote
Old 10-03-2012, 02:23 PM   #76
You can wire a "kill switch" so when you flip the switch the scanner will turn on with the last function it was on.
Old 10-03-2012, 02:48 PM   #77
FRANK121
FRANK121's Avatar
Like this?
Black Rally Stripes
6 Speed Automatic
Whipple 2.9L
LS3 Conversion
GMMP Axle Backs
Yank 2800 Stall
RotoFab CAI
Tuned By DSX Tuning
GM Quarter Flares
Camaro Floor Mats
Old 10-03-2012, 03:13 PM   #78
Like this?
Yes, exactly like that!
Old 10-03-2012, 03:55 PM   #79
Haole
2017 SS
Haole's Avatar
Scanner is installed. Will post video when I get to work. I cant post from my phone. So need to send from phone to email at work then hopefully I can post.
Old 10-04-2012, 09:02 PM   #80
Medic726
Medic726's Avatar
Drives: 2017 Camaro RS Auto
Medic726 is offline   Reply With Quote
Old 10-04-2012, 09:04 PM   #81
Medic726
Medic726's Avatar
Old 10-05-2012, 01:08 AM   #82
Haole
2017 SS
Haole's Avatar
Nice, My video look the same except in an IOM SS, for some reason the computer doesnt recognize the video format from my phone.
Old 10-05-2012, 09:23 AM   #83
AACstyle
AACstyle's Avatar
Originally Posted by Medic726 View Post
Video looks great, thanks for posting!
Old 10-09-2012, 11:59 AM   #84
Bump for p3jason
