Cold Air Inductions
Old 09-21-2012, 08:56 AM   #1
TRock
TRock's Avatar
Drives: 2011 CGM 2SS/RS
What is the best line lock?
As the title says I am looking to buy a line lock. I have only been able to find a couple that are specific to the 5th gen. SLP, TCI and SJM. Which one are you running and how easy was the install? I'm not looking for the cheapest way out but i dont see the sense in spending almost 300 dollars for a name.
TRock is offline   Reply With Quote
Old 09-21-2012, 09:01 AM   #2
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
I don't have one, however I have installed a B&M line lock. It was an easy straight forward install. Apex has them on their site for $175 which should be in your price range.
http://www.apex-speed.com/hurst-roll...t-5671518.html
Drew10 is offline   Reply With Quote
Old 09-21-2012, 09:04 AM   #3
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
I have the SLP, install was a little pita.. but overall I love it...
kevin1106 is offline   Reply With Quote
Old 09-21-2012, 09:26 AM   #4
TRock
TRock's Avatar
Thanks guys, i just ordered the Hurst from APEX. Some good folks over there.
Old 09-25-2012, 08:41 PM   #5
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
Havent had any problems with my Hurst. Very easy install, maybe an hour tops and that includes bleeding the breaks.
AngelSpeedFreak is offline   Reply With Quote
Old 09-25-2012, 09:11 PM   #6
timtoolman24
timtoolman24's Avatar
Drives: 2012 LS3 2SS/RS
Call me a new be haha but what and how does a line lock work?
timtoolman24 is offline   Reply With Quote
Old 09-25-2012, 09:11 PM   #7
TRock
TRock's Avatar
Just finished installing. It was pretty easy install aside from bleeding the bakes. I bought the vacuum bleeder from autozone, after 3-4 times trying to get all the air out, i finally decided to resort to the old school method. All is good now.
Old 09-25-2012, 09:14 PM   #8
TRock
TRock's Avatar
I noticed every time i activate and test it, i get a "service stabilitrak" message in the DIC. Anybody else have this issue? Or is it normal? It eventually goes away after it sits for a while.
Old 09-25-2012, 09:17 PM   #9
BigRed
BigRed's Avatar
Drives: SS RS SIM
It is totally normal. Happens everytime.
BigRed is offline   Reply With Quote
Old 09-25-2012, 09:19 PM   #10
TRock
TRock's Avatar
A line lock is a solenoid that you install in line with your front brake line coming off the master cylinder. Its used for doing a good burnout before a race, and can also be used when staging to leep from rolling out of the lights. Once you arm it you press on the brake pedal, hold the activate button down, release the brake pedal, this holds the front brakes and allows the back wheels to spin freely. Saves wear and tear on the brakes
Old 09-26-2012, 04:41 PM   #11
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
If it really bothers you, you can do a mod that will reset the Stabilitrak once the line-lock is released. It's a pretty easy mod.
The thread for it is here: http://www.camaro5.com/forums/showth...ight=line+lock
The info you need starts at post #18.
Three of Swords is offline   Reply With Quote
Old 09-26-2012, 06:19 PM   #12
TRock
TRock's Avatar
That link keeps coming up. "Error 404 - Not Found"
Old 09-26-2012, 09:03 PM   #13
Three of Swords
Fixed the link. Sorry.
Old 09-26-2012, 09:19 PM   #14
TRock
TRock's Avatar
Cool, thanks for the info. I always turn everything off when im racing anyways, but would be nice to be able to reset it and turn the lights off.
