09-21-2012, 11:46 AM | #1 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
Fuse pull highly recommended
After seeing some discussion on this forum about the fuse pull. I decided to give it a try. I pulled fuses 5 and 20 overnight. Took the car out to my favorite "closed course" and opened it up this morning. First thing, I can't get the tires to hook up at all in first. I used to be able to roll into the throttle, and it would spin some but catch and pull hard to redline. Now immediately hits the rev limiter.
Then, in second gear, I had figured out exactly where to shift using the onboard shift light. When all dots turn solid. Now, nope hit the rev limiter everytime. Engine is just reving too quickly. Thirdly, I got a forth gear chirp, at 98mph.
2017 ZL1
A10 Redhot with stripe Last edited by Blown355; 10-17-2012 at 07:41 PM. |
09-21-2012, 12:10 PM | #2 |
Drives: '81-Z28/'07-Tundra/'12-ZL1/'13-Jeep Join Date: Oct 2011
Awesome, I'm trying it when I get home.
ZL1 #612
09-21-2012, 12:12 PM | #3 |
Drives: 2015 Challenger SRT Join Date: May 2011
Interesting that the fuse pull even works on the ZL1! Can't say I'm really surprised though. It definitely wakes these cars up!
09-21-2012, 12:49 PM | #4 | |
Drives: 1968 Pro Touring SS Camaro Join Date: Jun 2012
2012 ZL1 Camaro - 6 speed, IOM, Black 20s, Ambient Lighting, Exposed CF Hood, #486.
2008 DMAX - Modded, lifted, smokin w/ 900 ft/lbs! 2009 335i - Modded, 425 whp 2012 X5 35D - Diesel, JBD chipset coming soon (550 ft/lbs) |
09-21-2012, 12:55 PM | #5 |
Drives: C6 Z06 Join Date: Jan 2010
Pull them and leave them out? Or pull and put back in?
09-21-2012, 12:58 PM | #6 |
one wheelin
i think its pull and leave out.
09-21-2012, 01:00 PM | #7 |
knows 2 facts about ducks
There is a sticky in the V8 sub forum that goes into detail what the fuse pull does. But in short, the Camaro isn't capable of re-learning fuel trims. So once you're in the low octane table you're stuck there. Fuse pull resets the fuel map.
09-21-2012, 01:06 PM | #8 |
what does it do. and does it make a diff. if you have ran 93 oct.
form day 1. or if you had a tune |
09-21-2012, 01:06 PM | #9 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
car more than likely will not start with those fuse left out this fuse pull just clears the PCM tables so it will be in high octane vs. regular octane fuel table definatly need to reinstall the fuses after the pull just do a search if you don't know vs. guessing false info
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
09-21-2012, 01:10 PM | #10 |
Lightning & Thunder
09-21-2012, 01:10 PM | #11 | |
one wheelin
09-21-2012, 01:12 PM | #12 |
Drives: 2006 Silverado SS, 2009 G8 GT Join Date: Aug 2008
09-21-2012, 01:18 PM | #13 |
Drives: 2013 ZL1 M6 SIM AGM mono stripe Join Date: Jul 2012
What are fuel trims? How do you "get stuck" in the low octane table? Does one tank of 91 octane gas reset the map at that lower level?
09-21-2012, 01:19 PM | #14 | |
Drives: car Join Date: Sep 2012
But the cars arrive to the dealers with very little gas. Do you think that the little it comes with from GM is 93 though? I'm talking before the dealer fills it... |
Thread Tools | |
