Old 09-21-2012, 05:28 PM   #1
2ss black
2ss black's Avatar
Drives: black2ss
is any one running the stock tune
is any one running the stock tune with hi flow cats a vararam intake a vmax tb ud pulley if so how fast is your 1/4 mile time and speed because i have the same setup and would to know thank for the help
2ss black is offline   Reply With Quote
Old 09-22-2012, 12:56 PM   #2
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Go run it, if it's a m6 you should have high 12s @ 110 or even a little better. Depends on your driving and elevation. My guess if you don't have experience you'll be in the low 13s after a few passes. I have seen full Bolton 5th gens run 14s because the guy has no idea what he is doing behind the wheel.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 09-22-2012, 08:08 PM   #3
2ss black
2ss black's Avatar
Drives: black2ss
it a
it a a6 what do u think a friend have a a6 also and all he have is a tune and headers and he when 12.81 at 108
Old 09-22-2012, 08:13 PM   #4
Bad70supreme
12.8s about right, you should be there too. Allot depends on air temp, elevation at the track that day. If your under 2000ft you should see high 12s then, if your in real good air like 500ft you could see 12.6 @ 110 With a auto I would foot brake the car to about 1500 rpm for the launch. Lower rear tire pressure to about 25-27 and do a good burnout. It won't take much to run low 12s with an auto, easy to drive
Old 09-22-2012, 10:00 PM   #5
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
FWIW I run an underdrive pulley and didn't bump up my idle rpms, and I still charge at 12.7 at idle in traffic and see 13.8 on the highway.
What does your car run stock?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
