sjm autoprod
Old 09-21-2012, 11:17 PM   #1
2qwik2katch
2qwik2katch's Avatar
Drives: 2013 Camaro SS
npp exhaust fuse pull
Tomorrow I will be picking up my new 2013 Camaro SS. I was wondering if anyone has done the fuse removal to keep the exhaust valves open at all times? Can someone please explain to me which one or ones I need to pull out to make this happen?
2qwik2katch is offline   Reply With Quote
Old 12-13-2012, 10:31 PM   #2
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
PLEASE RESPOND.
I am picking mine up tomorrow, I would like to know what fuse/fuses it is as well.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake | Pfadt Suspension | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 686rwhp/590rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 12-14-2012, 12:41 AM   #3
Dynamite
Dynamite's Avatar
Drives: 2013 Camaro 2SS/RS XD
Look on youtube or the V8 section. I saw it over there somewhere with a diagram.
Dynamite is offline   Reply With Quote
Old 12-14-2012, 02:39 PM   #4
YOOG
Drives: 2013 1SS LS3
There's a fuse box in the trunk on the passenger side behind the carpet. The fuse you want is F8. Apparently, you have to remove the inner rear plastic, then the 2 push pins holding the carpet and it should be revealed (got this info from pwrmanpaul66).
I couldn't release the carpet after doing all of that so if you figure it out, please let me know!
By the way, the dual mode exhaust is brilliant!
Dual Mode Exhaust | 6 Speed Manual | CAI Intake| BMR 1" Springs| Factory Reproductions 9" wheels
YOOG is offline   Reply With Quote
Old 12-14-2012, 02:49 PM   #5
woodstock
woodstock's Avatar
Drives: 2012 Corvette Grand Sport
I know on a Corvette it's the bottom right fuse in the box,the fuse panels may be similar,just read on the fuse box cover which fuse controls the NPP exhaust.
Casper is a 2012 Corvette Grand Sport w/ Heritage package.
woodstock is offline   Reply With Quote
Old 01-22-2013, 12:32 PM   #6
wakespeak
wakespeak's Avatar
Drives: 2013 2SS LS3/NPP
Pulled mine this past weekend. I noticed the engine spins easier during shifts, which I didn't expect. Must have something to do with reduced back pressure.
Anyway I love the sound and the engine feels happier. It does boom in 6th below 65 mph, so I may consider a switch.
YOOG, remove the back panel, then the spare time cover to allow access to the side carpet. I could not get the top push pin out (the lower one screws on/off), but the carpet slid over it without tearing.
wakespeak is offline   Reply With Quote
Old 07-09-2013, 09:44 PM   #7
Stackerz71
Drives: Camaro SS 1LE
Couldn't agree more with wakespeak...shifts are much smoother (especially 1st to 2nd) and the car sounds incredible under 3k RPM. Took all of five minutes to find and remove. Can't get enough of the sound of God!
Stackerz71 is offline   Reply With Quote
Old 07-09-2013, 10:03 PM   #8
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Did mine on day two and never looked back. Car sound great and shifts very smooth.
chevy 3 is offline   Reply With Quote
Old 07-10-2013, 03:11 AM   #9
Seabass33
Seabass33's Avatar
Drives: 2010 Camaro 2SS/RS Aqua Blue
I have an Borla Axle back exhaust do i still have those then? If yes can someone post a pic of it?
2010 Camaro 2SS/RS, Tinted Windows, ZL1 Front Fascia, ZL1 Hood Insert, 5 Spoke OEM ZL1 Wheels, Borla S-Type Cat Back Exhaust, JBA headers with Off Road Pipes, KW V1 Coilovers, H&R Sway Bars - Tuned by Ted Jannetty -
Seabass33 is offline   Reply With Quote
Old 07-10-2013, 04:58 PM   #10
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: 2013 ZL1 Black, aka "Big SexZ"
It's only on the dual mode factory exhaust.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
