Caryle Racing
Old 09-22-2012, 04:52 PM   #1
natmad
natmad's Avatar
Drives: WTB '16 1SS Magride NPP Recaros 6m
One more reason to like ZL1 tranny in 1LE...
I want to buy a silver 1SS 1LE with dual mode exhaust when my son gets one year driving experience in April as insurance costs go will then go down significantly.
I looked through and searched the Camaro Issues/Problems forum for any reliability concerns I might have about buying a Camaro 1LE. The one thing that really got my attention was the 1st to 2nd shift grinding issue that some owners have had with their 6 speed transmissions. From the reading I've done on mustang forums, it appears the Tremec has far less shifting issues than the Chinese made Getrag 6 speed in the Gt and Boss 302.
Soooo, since the 1LE has the ZL1 transmission, I searched the ZL1 forum and through 20 plus pages I found no threads concerning shifting issues. This is comforting to me as perhaps Chevy instructed Tremec to make sure this problem would not rear its ugly head on a $55,000 Camaro. Different parts, materials or a slight change in design, maybe.
Is this just wishful thinking on my part... time for a Saturday afternoon beer... cheers to my fellow 1LE fans.
natmad is offline   Reply With Quote
Old 09-22-2012, 05:00 PM   #2
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
The transmission in the 1LE is not the ZL1 transmission. ZL1 has the MG9, ,the 1LE has the MM6. I have heard that the MM6 is used in the ZO6.
Old 09-23-2012, 12:26 AM   #3
natmad
natmad's Avatar
Ok , wishful thinking and misinformation... time for another beer...
Old 09-23-2012, 12:57 AM   #4
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
They all use the Tr6060 but with different gear ratios.
Bhobbs is offline   Reply With Quote
Old 09-25-2012, 03:55 PM   #5
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
My 2012 ss has the carbon blocker rings to eliminate the grinding. So far so good. Would think all 2012 and up has this fix
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 09-25-2012, 05:32 PM   #6
1LEE
1LEE's Avatar
Drives: 2007 Cobalt SS/SC
This.
1LEE is offline   Reply With Quote
Old 10-04-2012, 11:06 AM   #7
2012REDSS
Drives: 2012 Camaro SS
I have a 2012 and my grinds but only are hard high rpm shifts
2012REDSS is offline   Reply With Quote
Old 10-04-2012, 01:47 PM   #8
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
He said it has the Z06 transmission...pretty stout and tested I'd say.
2cnd chance is offline   Reply With Quote
Old 10-04-2012, 02:31 PM   #9
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Sounds more like clutch not fully disengaging.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 11-19-2012, 10:44 PM   #10
BLKSS1LE
Drives: 2013 Chevy Camaro SS 1LE
I have a 1le and so far I am not impressed with the 1st to 2nd. It isnt grinding but rather not letting me into 2nd. And when it does it will not grind or make a peep! Now if I sit at a red light hold the break and put it into first and then 2nd it will do the same thing resist the shift. But once I put it into first or 2nd once, go to neutral and try it again, it will go back into the same gear just fine. Same thing with down shifting to 2nd or 3rd, it will not allow me to go into that gear... until i hit a certin RPM or gas it up with the clutch in to it falls into place.
BLKSS1LE is offline   Reply With Quote
Old 11-19-2012, 10:47 PM   #11
dangjohnny
Drives: 2013 Evolution GSR
Maybe you need a skip shift eliminator kit.
dangjohnny is offline   Reply With Quote
Old 11-19-2012, 11:11 PM   #12
Bhobbs
Bhobbs's Avatar
Sounds like the skip shift.
Old 11-19-2012, 11:31 PM   #13
PYROLYSIS
PYROLYSIS's Avatar
Do not try to force the car into 2nd gear if it doesnt want you to. It's trying to make you shift from 1st to fourth. Buy a $30 skip shift elliminator and you won't have this problem anymore. They are easy to install. There should be a light coming on in the dash if this is the problem you are experiencing. I believe it says skip shift or something.
Old 11-19-2012, 11:32 PM   #14
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
As said, skip shift feature that forces u into 4th gear due to emisions. Read the owners manual and it will tell u when it turns off, I think around 19mph or so. The skip shift eliminator connector is like $20.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
