JDP Motorsports
Old 09-25-2012, 11:04 PM   #15
Redemption
Just Because!
Redemption's Avatar
Drives: 2010 SIM 2SSRS
Same thing I said. The black plastic that comes around the spring coil. Make sure that is still there and didn't get thrown in the trash.
Redemption is offline   Reply With Quote
Old 09-25-2012, 11:08 PM   #16
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Dznts View Post
Make sure springs wraps were installed! i had the same problem after my Pedders coils were installed!.
This.....
And were there any sway bars installed too? Or just the springs?
Old 09-25-2012, 11:15 PM   #17
PQ
Booooosted.
PQ's Avatar
Old 09-26-2012, 08:07 AM   #18
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
swaybar endlink had to be disconnected from the strut/shock during the install and is a common source of noise- make sure they got re-torqued to spec. stock endlink nut is 36lb/ft.
Old 09-26-2012, 08:14 AM   #19
tjg
Drives: 2014 1LT/RS NPP
Did that come on the stock springs?
tjg is offline   Reply With Quote
Old 09-26-2012, 08:15 AM   #20
Ventmaster
Ventmaster's Avatar
No.
Old 09-26-2012, 08:20 AM   #21
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Could you please provide more info? Thanks
In the rear the spring loops can rest on top of each other. You can put plastic sleeves on the spring to help prevent noise when the spring expands and compresses. Not sure what their called. Coil isolators maybe.
jeremywes is offline   Reply With Quote
Old 09-26-2012, 11:06 AM   #22
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Can you post a picture, similar to this one, but show the coil from the shock bottom up?
Old 09-26-2012, 10:10 PM   #23
tjg
I rotated the rear springs 180 degrees and the clunking went away.
Old 09-26-2012, 10:24 PM   #24
PQ
Booooosted.
PQ's Avatar
Seriously?
They were installed incorectly then. They are supposed to be butted up to the groove like in the pic I posted earlier in this thread.
That'll certainly do it.
Old 09-26-2012, 10:32 PM   #25
tjg
Seriously?
It seems to be a problem with the retainers that come with the DSE springs. By rotating the spring it provided more relief between the retainer and the coil beneath it. I am going to call them tomorrow to see why this doesn't seem right. It seems the retainer hangs too low.
Old 09-26-2012, 10:33 PM   #26
JusticePete
VIR Specialist
Retainer? Can you post a picture?
Old 09-26-2012, 10:43 PM   #27
tjg
I will have to take one tomorrow. It is a metal hook that keeps the top coil from becoming unseated at full droop. Maybe it is needed for these springs because they are 1.5" drop? I'm tempted to just take them off. I'm not planning on catching air anytime soon.
Old 09-26-2012, 10:46 PM   #28
PQ
Booooosted.
PQ's Avatar
clunk noise, springs, suspension noise
