B&M Racing
Old 06-01-2009, 01:38 AM   #1
Foglin
Drives: 2010 1SS, 1966 Chevelle LS1
Best way to launch with manual transmission?
Hi,
Just wondering, what is the best way to launch with the manual transmission on the strip (without launch control)?
I have some experience with auto ! That is just limiting the wheel spin with your foot (street tires)!!
I've read that the launch control is not the quickest way. Should one use more or less rpm off the line? I mean on a prepared drag strip, not on the street, but still with street tires.
Somebody give hint, because I need a time slip.
Foglin is offline   Reply With Quote
Old 06-01-2009, 01:39 AM   #2
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Release clutch, mash gas.
Disclaimer: I don't recommend listening to anything that I say since I don't know what I'm talking about.
Old 06-01-2009, 01:41 AM   #3
qbert48
qbert48's Avatar
Drives: 2SS SIM
yep+1
2SS RS SIM gray leather stick shift ground FX
thank you gary richards @ classic chevy in sugarland
welcome home
1100 4-27-09
6000 6-27-09
yes i got to the dance late don't hate me
qbert48 is offline   Reply With Quote
Old 06-01-2009, 04:13 AM   #4
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
Practice... practice and more practice till you get it right! Every clutch is different so the only thing you can do is learn your car!
2SSJIM is offline   Reply With Quote
Old 06-01-2009, 04:40 AM   #5
Camaro123
Drives: Pontiac GTO
Originally Posted by 2SSJIM View Post
Practice... practice and more practice till you get it right! Every clutch is different so the only thing you can do it learn your car!
Absolutely correct, you have to learn your car as every launch will be deferent depending on the tiers, asphalt, temperature, etc.
Good luck practicing
Camaro123 is offline   Reply With Quote
Old 06-01-2009, 05:34 AM   #6
lordfriday2
Proud Owner!
Drives: 2010 Camaro SS RS
Send a message via AIM to lordfriday2
don't launch at 4k at the track.... I learned that the hard way
lordfriday2 is offline   Reply With Quote
Old 06-01-2009, 08:44 AM   #7
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Do tell...
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 06-01-2009, 10:18 AM   #8
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Shouldn't this go in the racing section of the forum?
Kyle2k is offline   Reply With Quote
Old 06-01-2009, 10:22 AM   #9
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
I think a few of the review videos may have mentioned how they got their times. Might be a good reference.
Originally Posted by KILLER74Z28 View Post
Do tell...
http://www.camaro5.com/forums/showthread.php?t=25043
UCF w00t is offline   Reply With Quote
Old 06-03-2009, 04:01 PM   #10
2010 CAMARO SS RS
2010 CAMARO SS RS's Avatar
start at medium throttle for .75 second then floor it. when you shift from 1st to 2nd , and so on, take your foot off the clutch really fast and floor it!!!!!!!!!!!!! you will get no wheel spin.
2010 CAMARO SS RS is offline   Reply With Quote
Old 06-07-2009, 05:09 AM   #11
Foglin
Tried just what you described, otherwise all as "described"! But, had very serious wheelspin (and some wheel hop!) off the line. I tried anything between 1000 and 2000 as starting rpms. 2000 is too much for street tires and 1000 makes it bog! Once it gets up and goes it's a no brainer! chirps 1-2 shift as well as 2-3 shift!
Should I start as Granma? Just babying it off the line, as in any street corner? Or, should I go and buy Drag radials, or worst case: get a driving course
Guess I need more practice
But its fun
Old 06-07-2009, 05:36 PM   #12
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
But its fun
Try slipping the clutch a bit, just ease it out a bit slower when taking off. Try and concentrate on holding the rpm steady, watch the tach and keep it at say 2000rpm. Don't let it drop below 2k. Release the clutch a bit slower than during a normal 1-2 shift or 2-3 shift. As soon as you are almost all the way out with the clutch, roll onto the throttle quickly. Play with the rpm you leave at and the amount of time to let out the clutch until you find the best launch.
Obviously, you have to be careful not to slip it real bad, you probably don't want to put the engine at 5k and slip the clutch for 2 seconds, but you should be able to find a nice range where you get off the line quickly.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 06-08-2009, 02:48 PM   #13
Foglin
Thanks Rayhawk!
I figured it would be something like that, just don't want to burn the clutch. Maybe I was too concerned about that and popped the clutch to quickly. Need to practice, that all!
Old 06-09-2009, 10:32 AM   #14
War Eagle
War Eagle's Avatar
Drives: 1969 Chevelle, Avanti, 2010 GT500
With stock tires drive around the water. Experiment with RPM, try 2,000 to start with and as has been said ease the clutch out till you get some traction, then hammer it.
I had some terrible initial times with my GT500 on stock tires till I learned. I went from a 9.5 to 8.5 in the 1/8 mile pretty quickly.Your times will get better each time you run just remember to avoid the water. Run by yourself the first several times, less pressure.
Steve
Back in a Chevelle after 41 years.
War Eagle is offline   Reply With Quote
Remote Start on Manual Transmission Dentyneice Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 51 02-11-2015 02:56 PM
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 09:57 PM
Why aren't there any Aqua Blues yet? txcamarogirl 5th Gen Camaro SS LS LT General Discussions 40 08-20-2009 11:05 AM
launch control with manual? Ltdodge 5th Gen Camaro SS LS LT General Discussions 6 04-30-2009 07:52 AM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
