Jason 98 TA
Old 09-22-2012, 05:51 PM   #1
mercedestech
mercedestech's Avatar
Drives: 2010 2SS/RS IOM,2013 Mercedes ML350
Installed LPE twin pump setup today, p069e fault now?
Anyone run into P069E fault code after installing a LPE twin fuel pump and fpcm? The car runs great and my fuel pressure issues are finally taken care of.....now i have this check engine light. I'm sure it's something simple, just wondered if anyone else has run into it until I can call LPE on Monday.
The car runs sooooooooo much better now at WOT! Before my pressures would drop to 50-52 psi with a quick stab of the accelerator, now it actually jumps from 58psi to about 65 psi and stayed there until I hit the rev limiter in 4th! It actually took care of some of the minor driveability issues when quickly accelerating from a cruise also. Absolutely awesome setup LPE!!!!!
2010 Camaro 2SS/RS Whipple 2.9L, Rotofab CAI and coil covers, XS Power LT's and full 3" exhaust, Vengeance kaotic cam package (trunion kit,dual springs,titanium retainers,hardened pushrods,c5r chain,ls2 tensioner, melling oil pump) Mgw shifter, 160 deg Tstat, prosport gauges, LPE dual pump, FIC 60lb injectors, level 5 DSS Axles
1994 Z28 MSD optispark, K&N CAI, Magnaflow y pipe..Cat..and cat back. 1998 wheels, custom tune(sold )
1993 Base V6 sold to buy Z28
1994 Purple Pearl V6...sold
1979 Base Car with inline 250ci 6 cyl! My first car in 1989!
mercedestech is offline   Reply With Quote
Old 09-23-2012, 08:13 PM   #2
mercedestech
After searching the forum for my fault code, found out that all of the vehicles with this code had a install issue. It was late by the time I got to the section involving switching all of the wires between connectors, so I thought I better check and make sure i put all of the wires in the correct spot on the new fpcm connector. Rechecked all of my wiring today, and found I put the wire that was supposed to go in pin 17 in pin 33 (one row down right underneath 17) on the new fpcm. I guess thats what I get for rushing.
All is good now, check engine light is off and best of all no fuel pressure drop at WOT!!!
