BORLA
Old 09-23-2012, 06:40 PM   #1
Mersades
Web Geek Chick & NHRA fan
Mersades's Avatar
Drives: 2010 2SS LS3 RJM
Question about wax
Hello everyone.
I purchased a used 2010 LLT at the end of July. I made sure to get her detailed and waxed up soon after I brought her home. Since then, I haven't had much need for a full water wash until the past few weeks.
I have noticed the past two times I washed her at home that the water beads up wonderfully when I do the initial spray, but when I rise after soaping, the water is not beading on the car as well. I waxed her again after the last wash, and the same happened again today. Is this normal behavior, and if not, what might be the culprit?
I used Meguiar's NXT Generation® Tech Wax. For wash, I used a bottle of Meguiar's Gold Class that my mom donated to me... I am not sure when she bought it, so I am wondering if it is old and losing its quality.
Mersades is offline   Reply With Quote
Old 09-23-2012, 06:41 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
It's not that unusual for it to not bead after the final rinse as much. If it's beading at first you're probably ok.
*In life, there are no nandroids*
[B]
Old 09-23-2012, 07:03 PM   #3
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Soap changes the surface tension of water, so it is harder for it to bead.
It just kinda collapses.
GVA 45TH 2SS is offline   Reply With Quote
Old 09-23-2012, 07:20 PM   #4
Mersades
Mersades's Avatar
Good to know. This is the first car that I've cared enough to wash by hand, so I want to be careful that I'm doing it right. I will make sure the water is beading if she gets rained on, or the next time I do a pre-wash rinse, and relax in the meantime.
Thanks for the feedback!
Old 09-24-2012, 04:41 AM   #5
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
Some soap's will degrade the wax on any finish quicker then other's and you will notice it, so I recommend you to use a sealant and a QD that has or is a Polymer Spray like Blackfire. If your going to stay using a wax then Blackfire has a Midnight Sun Instant Detailer Spray that will maintain your wax finish till you need to wax it again. Remember that wax will break down faster then a sealant so keep it up with the right products to keep your finish protected. Hope to see more pictures of your New Camaro soon.
Old 09-24-2012, 04:55 AM   #6
Amclymon
Drives: 11 maro 1ss
co sign......
wax kinda wears off after soap contact.... still protected but after a few washes.. wax again
the chemical car washes.. was comes right off
Amclymon is offline   Reply With Quote
