B&M Racing
Old 09-23-2012, 09:57 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
Just installed a few goodies on #917
No pics...sorry. I went conservative with the upgrades but they should be worth 60-80rwhp. The mods are as follows:
ATI/Lingenfelter lower pulley with 9.55 ring...left top pulley stock. 50 mm lower idler.
160 thermostat
NGK TR6 spark plugs
ADM Race Air intake
Lingenfelter/Rotofab Intercooler reservoir
90mm Throttle Body
Tune by local dyno tuner this week.
My test drive was uneventful and I was just checking for leaks, pulley wobble, etc. At grandma speeds and light throttle, no CEL yet.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-09-2012, 12:16 PM   #2
Speedforhire
Speedforhire's Avatar
Drives: 2013 GRAND SPORT (aka: EREBUS)
So what was your final numbers after your tune?
Speedforhire is offline   Reply With Quote
Old 10-09-2012, 12:37 PM   #3
Stephen12ZL1
Drives: '17 ZL1 A10
553hp/563tq....sae corrected. actual on a hot day was 543/553. It is waaay stronger on the street. Feels like it should have from the factory with minimal mods.
Old 10-09-2012, 12:42 PM   #4
Nemisis
Drives: 2013 Ashen Gray Metallic-M6
Based on the fact that you have an auto Id say those mods were worth about 80rwhp. I see a lot of dyno #'s on here for stock auto's around the 470 range. Nice numbers btw!
Nemisis is offline   Reply With Quote
Old 10-09-2012, 01:00 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
NICE
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 10-09-2012, 01:10 PM   #6
Stephen12ZL1
Drives: '17 ZL1 A10
SAE corrected stock was 478/481...so it was a nice jump. Feels great and the tires scream for mercy now. With the cooler weather, it should be running some decent times at the strip soon!
Old 10-20-2012, 09:53 PM   #7
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
nice numbers......why did you go with a bigger lower pulley versus a smaller upper? Also, I was told when I do get ready to MOD, if I went to a 90mm TB to use an LS2 90mm TB instead of the LS3 90mm. You ever hear of that?
tnspd is offline   Reply With Quote
Old 10-20-2012, 10:14 PM   #8
Stephen12ZL1
Drives: '17 ZL1 A10
I went with the lower pulley because it was an easier swap and I didn't have to send out for a new snout etc. The 9.55 lower ring is close to the same boost as a 2.55 upper. Also, the ATI balancer is lighter than the stocker. I have never heard of a specific LS2 90mm TB but if they are both 90mm and bolt up just like stock with a "plug and play" wire connection, then they should perform identically. The listings on ebay say LS3 LS2 LS7 so maybe they all use the same part number. 90=90. I purchased the TB from ebay for $130ish. I felt like the more expensive choices (102mm etc) may not help much with a stock unported snout.
Old 10-21-2012, 01:13 PM   #9
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Is the 11.19 on drag radials?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 10-21-2012, 01:20 PM   #10
Stephen12ZL1
Drives: '17 ZL1 A10
yes, of course. Traction is difficult without "sticky tires".
Old 10-21-2012, 01:32 PM   #11
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Tell me about it.
My trip to the track (before any mods) resulted in 13's with 2.7 - 2.8 60 fts...lol
I just thought you seemed to have pretty good stock tire times, so it wasn't a huge stretch to the 11's.
My car is a manual though and launch traction is a HUGE problem.
2012 ZL1
Old 10-21-2012, 01:42 PM   #12
audiomikej
audiomikej's Avatar
Drives: the wife crazy talking Camaros
How about a pic of the new TB
audiomikej is offline   Reply With Quote
Old 10-21-2012, 02:24 PM   #13
Stephen12ZL1
Drives: '17 ZL1 A10
exactly like this
http://www.ebay.com/itm/LS3-LS7-L99-...-/190698569801
Old 10-21-2012, 02:28 PM   #14
Stephen12ZL1
Drives: '17 ZL1 A10
you must get drag radials or your track runs will be a bust...that I can tell you with certainty.
