Old 09-26-2012, 12:06 AM   #1
Ehmsea
Ehmsea's Avatar
Drives: 2013 2SS RS Hurst NPP
Rx Catch can install on LS3
Hello everyone. I've been a member here only a few short months, but I have learned A LOT from this forum. What a wealth of information there is in here.
I thought I'd give a little back, so I made a video on how to install a oil catch can on a Camaro SS with the LS3 engine (6 speed manual). The video is pretty lengthy, and I'm no mechanic. But I think some of our members will find this helpful.
I ordered the catch can directly from Rx. There instructions were pretty good, with lots of detailed pictures. But, there was only one set of directions. If you have an LS3 do this, if L99 do this. Seems pretty easy except for when you don't know what some of the components are called. Then it gets a bit confusing.
Anyway, here is the link for a video I just posted on youtube. I must warn you, it is lengthy (17 min). But, I do cover the entire install. If I would have been able to watch one of these before doing it myself, it would have taken 1/4 of the time. Hopefully, someone will spend 17 minutes and save 4 hrs...
All corrections/comments will be welcome!
Thanks!
No Worries
CAI Intake w/washer relocation and race scoop
Ported Throttle Body (Polished)
Kooks LT stepped headers 1-3/4 to 1-7/8
High Flow Cats
Livernois Motorsports Stage 2c Cam Package
https://www.youtube.com/watch?v=AKXyCyBh9BU
Hill Start Assist Delete
Ehmsea is offline   Reply With Quote
Old 09-26-2012, 03:15 AM   #2
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Great job! I installed mine last week and this would have helped immensely. I'm sure it will be helping many future catch can installs.
Obzen is offline   Reply With Quote
Old 09-26-2012, 06:54 AM   #3
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
Is a catch can really needed? If so what is the advantage?
CamaroLS is offline   Reply With Quote
Old 09-26-2012, 04:06 PM   #4
ReoRockStar
ReoRockStar's Avatar
Drives: 2012 Camaro 2LT 45th AE
What are the positives and negatives of installing a catch can? I've seen mixed review. Thanks
ReoRockStar is offline   Reply With Quote
Old 09-26-2012, 05:38 PM   #5
Raptor3141
Raptor3141's Avatar
Drives: 2010 2SS/RS RJT M6
Thanks. I installed mine yesterday in about 20 minutes. It's so much easier when they send you the correct bracket.
Raptor3141 is offline   Reply With Quote
Old 09-26-2012, 05:44 PM   #6
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
That's been beat to death on this forum. Lets not bog this thread down with it.
I suggest you read through a few of these.
http://www.camaro5.com/forums/search...rchid=16625591
Old 09-26-2012, 06:20 PM   #7
SC2150
This is a good thread that is not a million pages long.
I have never heard of a con, but the pros are a long list:
http://www.camaro5.com/forums/showth...nding+catchcan
Old 09-26-2012, 06:29 PM   #8
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I was one of those who said it doesn't matter if you have a catch can or not.
Then I removed my manifold to install my blower and had the oil pour out onto me. I was shocked at the amount. An intake manifold should really be DRY. And here I was dripping dirty oil all over. And my valve tops were soiled.
For the money I'd say it's a good preventative. ESPECIALLY with a blower with an intercooler.
Nice job on the install.
Old 10-02-2012, 04:45 PM   #9
Ebbsnflows
Drives: 2018 Camaro ZL1-1LE
Thanks for the install vid...as you very "diplomatically" described in the video, the included instructions and those on the website are essentially worthless. They had me trying to connect the can to a nipple located on the rear of my intake, when I should've been connecting to the two nipples located near the back of the T-body. Of course the random picture of the LS1 motor/throttlebody didn't help too much with my LS3 motor install.
2018 Camaro ZL1/1LE
Ebbsnflows is offline   Reply With Quote
Old 10-04-2012, 06:37 PM   #10
Fyx
Drives: 2013 2SS/RS
Subscribed, doing an install soon. Do you have larger than average hands? I'm not comfortable disconnecting everything like you did, hoping to either get my girl to help or shrink my hands.
Fyx is offline   Reply With Quote
Old 10-05-2012, 12:28 PM   #11
Ivan @ Southwest Speed
Thank you for posting the video up! Folks need to see more of these out there.
Definitely a great thing for all the Camaros!
Ivan
Old 10-05-2012, 01:20 PM   #12
SC2150
Excellent!! Many thanks.
Old 10-15-2012, 12:32 PM   #13
Ehmsea
Ehmsea's Avatar
I removed more than I needed to...
Well, I would say that I have average size hands with long fingers. The only reason why I removed all those plugs is because I did not know how to operate the connectors on the U-shaped tube. I wanted to get in there to see what I needed to do and also I thought it was a push and twist, and I could not get my hand in there to twist.
Now, after having done it. I know the clasp can be undone with a finger or thumb, and then just pulled off (top one first). Then unbend the U and twist about 180 deg to expose the clasp on the bottom one. Also, you would not need to remove all the other plumbing like I did. I just did not know where to route all the stuff, so I thought I'd best to remove and replace.
good luck. PM me if you have any questions...
Ehmsea
No Worries
High Flow Cats
Old 10-16-2012, 09:30 AM   #14
a.morblu
a.morblu's Avatar
Drives: 2011 Sinister SS
Very nice
a.morblu is offline   Reply With Quote
catch can, catch can instal, rx catch can
