HeadlightArmor
Old 09-26-2012, 08:26 AM   #1
montana7mm
Drives: '13 ZL1/'11 IMPALA LTZ/'06 HUMMER
ZL1 Front splash guards
Anyone have ideas on a front splash guard for a ZL1? I'm looking for something resembling the rear factory installed unit on the ZL1. Can the rear units be modified to fit work on the front? Can the existing units installed on the front-of-the-front-wheel-well be utilized to worked as a traditional splash guard? Will a existing C5 or C6 Corvette unit work? I hate to see my 2013/VIN1199/ZL1 unprotected from front tire thrown road hazards.
montana7mm is offline   Reply With Quote
Old 09-26-2012, 08:30 AM   #2
toddsZL1
Drives: 2012 ZL1 IOM#1645
I know a good body shop in Shawano!
toddsZL1 is offline   Reply With Quote
Old 09-26-2012, 09:45 AM   #3
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
I made my own. Used a piece of card board to trace the back "canard" as the template, and modified the shape slightly.
Purchased some flat "truck" sized splash guards, used tin snips to cut and trimmed to fit. Gave the cut edges of the matched pair a quick sand with my belt sander.
Used little slip clips to mount to fender. Placed a strip of electrical tape between the paint and splash guard.
THR ZL1 #1 is offline   Reply With Quote
Old 09-26-2012, 09:46 AM   #4
firecross91
firecross91's Avatar
Drives: ZL1 #1691 Black on black.
firecross91 is offline   Reply With Quote
Old 09-26-2012, 09:54 AM   #5
THR ZL1 #1
Perma Grinning
Best pic I have access to . .
Car's I drive:
2017 Tom Henry Racing ZL1 Convertible, 2016 Silverado High Country HD, 2014 Camaro SS Convertible, 2014 Acadia Denali, 2012 Tom Henry Racing ZL1, 2002 Berger SS Phase II, 2001 Camaro SS Convertible, 1997 Hendrick Motorsports 30th Anniversary LT4 SS, 1992 Camaro RS Z03 25th . . .
Old 09-26-2012, 09:58 AM   #6
firecross91
TY I think I would paint the clips black.
Old 09-26-2012, 11:19 AM   #7
THR ZL1 #1
Perma Grinning
Exclamation
OK got some more pics up:
Mounting - Yes I need to paint the clips:
Finished look:
Old 09-26-2012, 11:34 AM   #8
THR ZL1 #1
Perma Grinning
I put together a DIY . . .
http://www.camaro5.com/forums/showthread.php?t=252329
Old 09-26-2012, 11:37 AM   #9
montana7mm
Thanks THR ZL1 #1.
I'll work with "ToddsZL1" to copy your design. He does a first rate facility in Shawano.
Old 09-26-2012, 11:10 PM   #10
gregbzl1
gregbzl1's Avatar
Drives: 2013 ZL1 WHITE W/CF HOOD INSERT
Originally Posted by montana7mm View Post
Thanks THR ZL1 #1.
Look at a new vette they appear to be flat and the same material and i think they would work. T rear zl1 splash shield appears to be wide but would have to be modified.I have been looking for the same cure with 2000 miles on mine i have a few small chips already.
gregbzl1 is offline   Reply With Quote
Old 10-13-2012, 08:44 PM   #11
shiner98
shiner98's Avatar
Drives: 13 AshGray M6 ZL1 w/Nav/ECF/Sunroof
Here's how mine came out
I took THR's idea and here's how mine came out. I didn't use electrical tape between the flap and paint since the flap only sits against the fender wall lip and the flap does not "flap" in the wind.
http://www.camaro5.com/forums/showth...16#post5690516
shiner98 is offline   Reply With Quote
Old 10-24-2012, 10:02 PM   #12
OVERPAR73
2013 CRT ZL1 convertible
OVERPAR73's Avatar
Drives: 2013 ZL1 vert
ZL1 front splash guard
Here is how mine came out when I visited all the DIY threads. These should of came from the factory just like this.
OVERPAR73 is offline   Reply With Quote
Old 12-15-2012, 04:29 AM   #13
ZL1speed
Drives: 2013 ZL1 Victory Red
Do they sell any made up for the ZL1 ? from Chevy instead of making them?
ZL1speed is offline   Reply With Quote
Old 12-15-2012, 07:51 AM   #14
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Vett ones will not work, I bought a set and tried, they tarper from thin to thick, they won't work.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
