B&M Racing
Old 09-26-2012, 10:05 AM   #1
Sharp-ZL1
MSG,Retired US. ARMY
Sharp-ZL1's Avatar
Drives: 2012 ZL1, 11 XC 90, 15 BMW 328i SW
Torq Specs
Anybody know what the torq spec for Item 30 Is? REAR SUSPENSION / REAR SUSPENSION / SUSPENSION COMPONENTS / Susp crossmember bolt
I think its 100 Ft lbs but want to make sure. Had to loose them in order to install Toe Rod on the left side. thank you.
Sharp-ZL1 is offline   Reply With Quote
Old 09-26-2012, 10:18 AM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Bush Timing
Step 1. Lift the car on a two post lift and raise it.
Step 2. Loosen the following bolts/nuts:
Front:
---Inner Control Arm Bushing
---Inner Radius Rod
Rear:
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Lower the car and drive it around the parking lot SLOWLY and on to the alignment lift.
Step 4.
With the weight of the car on the wheels tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
Alignment
Front and Rear Bolt Torque Values
NOTE: Torque specifications that read XX torque value and XX degrees are usually TTY and require replacement of the bolt, nut or both. If replacement parts are not available from GM the minimum acceptable torque will be those values stated along with a liberal application of a thread locker i.e. LocTite.
Old 09-26-2012, 01:12 PM   #3
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Most epic thread jack of all time
KKreme15 is offline   Reply With Quote
Old 09-26-2012, 01:27 PM   #4
JusticePete
I only meant to paste the data portion
Old 09-26-2012, 04:09 PM   #5
HDRDTD
HDRDTD is online now   Reply With Quote
Old 09-26-2012, 04:30 PM   #6
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
Well, it's all interesting nonetheless!
Happy_Dan is offline   Reply With Quote
Old 09-26-2012, 04:35 PM   #7
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Originally Posted by HDRDTD View Post
You weren't in before the edit. It was like a Pedders commercial lol
