Old 09-26-2012, 01:22 PM   #1
sspddmn
sspddmn's Avatar
Drives: 2013 ZL1 and 1991 Z28
EXCESSIVE CLUTCH CHATTER
Anyone else have this? Everytime I let out the clutch all the way through 3rd gear I hear the rattle. And when I let off the clutch a little harder (instead of gently letting off the clutch) the rattle from the transmission seems harsher and louder too.
Are these transmissions suppose to have excessive clutch chatter? Anyone else hear this too?
Thanks.
2002 Camaro SS (sold) / 1991 Camaro Z28 5.7L / 2013 ZL1 VIN# 149 / 2016 Audi A6 Prestige Supercharged 3.0 V6
sspddmn is offline   Reply With Quote
Old 09-26-2012, 01:31 PM   #2
4fbodys
4fbodys's Avatar
Drives: 3 3rd gens 1 4th gen
Do you hear the chatter at idle with the clutch out I hear it in my car the same but also hear a rattle under the car when i get out listen and it's not the supercharger plus 9500 miles and have had a new supercharger put on 1000 mile ago
4fbodys is offline   Reply With Quote
Old 09-26-2012, 01:51 PM   #3
OldScoolCamaro
Clutch "chatter" is normally associated with pulse/vibration in conjunction with noise. I think you mean just noise. There is nothing quiet about the mechanical operation of the ZL1 it's S/C, transmission, and driveline. Everything at times makes varying levels of noise. At idle you may hear noise coming from the transmission area from inside and outside. Inside the car you may hear noise coming from the area of the transmission tunnel. It can be at one time or another in any area of operation from shifting, to driving in gear, or sitting in neutral. Also the rear axles, carrier/rear axle housing talk alot. If the noise is at the same relative level as any other mechanical sound(s) of operation and does not get higher or more pronounced over time then it's what's baked in the cake. The HD stuff tends to act that way.
Old 09-27-2012, 08:33 AM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
Thanks.
If you feel this may be an issue, you always have the option to bring it to a dealership for a proper diagnosis! Please let us know what you were able to find out.
Brandon
Chevrolet Customer Service
Old 09-27-2012, 11:18 AM   #5
flyjbaker
Drives: none yet
I have not owned a Camaro....YET. But I had that chatter on both of my Corvettes and my GTO.
flyjbaker is offline   Reply With Quote
Old 09-27-2012, 11:54 AM   #6
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Based on the SS, I would say it's just the slop in the drive line and the throw out bearing making noise. This is very common on the SS, especially when driving slow through a parking lot.
Old 09-27-2012, 12:23 PM   #7
sspddmn
sspddmn's Avatar
i see. Thanks for all the input. Ill bring it up when i take my Z in for my oil change.
