ADM PERFORMANCE
Old 09-26-2012, 07:42 PM   #1
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
Engine cover painting tips?
So today I painted the engine cover to my car Blue and silver, and once I took off the tape it looked terrible! The actual paint color was great but once the tape came off chunks of the paint came off as well, and I spent like an hour taping up everything, and it still came out all sloppy. I have seen people on here who have painted their own engine covers and it looks awesome, but mine just didn't turn out like I hoped, so I am gonna re do it this weekend. does anyone have any tips or advice on how I can get it done the cleanest/most professional look possible?
Aubrey64 is offline   Reply With Quote
Old 09-26-2012, 07:43 PM   #2
Aubrey64
Aubrey64's Avatar
Also when I re do it, do I need to get off all the paint before I re paint it?
Old 09-26-2012, 10:05 PM   #3
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I would say try light sanding instead of taking it all off. Sand and blend in where it was ripped off, of course I dont know how bad it was.But be carefull, you know how the surface is textured? If smooth to much in the bad areas may have to sand it all, but people do that to get the smooth look.Me, I wasnt going that crazy with it.If that doesnt work well enough you can take it off, but I never tried that. We all get a bit of paint that lifts off, mine was at the edges so I masked the good areas and re shot it, or in small areas use a paint brush.Main thing here is to let one color dry complaetely, overnight anyway, then mask off to do the other. My paint process was as follows:
2-4 coats of adhesion promoter for plastic
4-6 coats main color
3-4 coats of clear
All paints were from Duplicolor
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/427 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 09-26-2012, 10:20 PM   #4
Aubrey64
Aubrey64's Avatar
3-4 coats of clear
Thanks for the help! I will probably just redo it all because what isn't peeled off, just looks pretty sloppy. I should have trusted my own judgement, because I knew that I needed to prep with sanding and adhesive promoter but the guy at Auto Zone insisted that that step was unnecessary so I listened to him...Which was definitely the wrong decision, I should've trusted my own judgement, because my lack of proper prep work was probably what screwed me over
Old 09-26-2012, 10:52 PM   #5
J-ROD-210
J-ROD-210's Avatar
Drives: 2010 Camaro SS/RS RJT A6
Don't worry,mine looks like crap too because I used cheap aerosol paint.The can said it was specifically for plastic and the same brand clear made it worse.
J-ROD-210 is offline   Reply With Quote
Old 09-26-2012, 11:06 PM   #6
Red Jewel RS
Red Jewel RS's Avatar
Drives: 2017 Camaro 2SS
I got bubbles in mine and had to redo. What I have found is use several light coats and let dry between. On the last coat before you use clear, pull tape off slowly before the paint is completely dry.
I'm not a professional be any means but it work for me.
hope this helps. Good luck!
Red Jewel RS is offline   Reply With Quote
diy, diy painted engine cover, diy painting, engine cover
