SDPC
Old 09-26-2012, 08:41 PM   #1
jackscf16
Drives: 2011 camaro ss procharged, headers
camaro ss 700 whp supporting mods.
What all do I need pro charged set up
jackscf16 is offline   Reply With Quote
Old 09-26-2012, 08:44 PM   #2
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
You going to need to invest in a quite a bit if you want to make 700whp safely. I would recommend swapping out your engine or forging the one you currently have. With a cam and turning up the boost on the procharger, you can get 650, but you should upgrade your fuel system and injectors as well. There are a lot of different options for fuel systems and upgrading your motor internals. I'm sure a vendor will post up shortly and be able to answer specific questions about certain products.
It would also be helpful to post up details on what kind of power you are currently making and your car specs.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
