BeckyD@RodgersChevrolet
Old 09-27-2012, 08:14 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28
Video of dyno runs today...much improved!
This is a video of today's dyno runs. ADM air intake, 90mm TB, 9.55 ring ATI balancer(13psi) and custom tune. Very happy with 554hp/563tq now vs 478/482.
'15 Z/28 #325 black a/c & stereo. 2:10.9 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 09-27-2012, 11:22 PM   #2
Taser Deployed
Taser Deployed's Avatar
Drives: 2012 Blk ZL1
Nice. Can you feel a difference in the power?
Taser Deployed is offline   Reply With Quote
Old 09-28-2012, 04:49 AM   #3
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
wowza. I would hope he can feel a difference.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 09-28-2012, 06:30 AM   #4
Stephen12ZL1
Drives: '15 Z/28
Yes, the difference is very noticable. The blower whine is much more pronounced as the blower is spinning faster now. This tuner took his time and really did a good job dialing it in. It has manners just like stock idling and cruising too.
Old 09-28-2012, 06:59 AM   #5
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
That will make the car more fun
Tampa Tuning is offline   Reply With Quote
Old 09-28-2012, 08:53 AM   #6
Blown355
Blown355's Avatar
Drives: 2012 ZL1
This is the same setup I'm going with. Did you have to upgrade the injectors?
2012 ZL1
10 spoke
M6
ECF
Blown355 is offline   Reply With Quote
Old 09-28-2012, 09:21 AM   #7
Stephen12ZL1
Drives: '15 Z/28
I did not upgrage the injectors and he said I was fine with the fueling on the car in the mid 10's. Leaning out the car to 11.4 or so did nothing for the hp or tq. Actually, the car liked being slightly in the rich zone. He said if I do any other mods I would have to swap injectors to something higher flowing as they were "static" most of the dyno run. As of now, I don't plan to upgrade any more. It all depends upon what it runs at the strip. I would love to think it will run 11.5@120 or so. It sure feels stronger all the way through the rpm band.
Old 09-28-2012, 10:04 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
NICE!!! Great set-up; I love FI'd cars, mostly because of the modibility and smog-crap I have to deal with. I also loved that you put a mic' on the SC
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 09-28-2012, 12:09 PM   #9
Speedforhire
Speedforhire's Avatar
Drives: 2013 GRAND SPORT (aka: EREBUS)
Great numbers........and sounds like you got the most bang for your buck. Exactly the same goals i'm shooting for. Thanks for sharing here.
Speedforhire is offline   Reply With Quote
Old 09-28-2012, 02:03 PM   #10
Nemisis
Drives: 2013 Ashen Gray Metallic-M6
Dang, I'm going to run a 10" pulley which is only 1 more lb of boost and cai and I keep having people tell me I need injectors??? Nice numbers btw.
Nemisis is offline   Reply With Quote
Old 09-28-2012, 02:34 PM   #11
b_williams_82
b_williams_82's Avatar
Drives: 2013 ZL1 #142
Is this the 650 package from ADM?
Order # QHQWJF
Current Status: 4200 VIN 142
1100, (04/25/12): 2000, (05/21/12): 2500, (5/22/12): 3000, (5/22/12): 3100, (5/31/12): 3300, (5/31/12): 3400, (6/7/2012): 3800, (6/15/2012): 4000, (6/15/2012): 4104, (6/15/2012): 4106, (6/19/2012): 4150, (6/19/2012), 4200, (7/16/2012), 4300, (7/18/2012), 4B00, (6/15/2012) , 5000, (7/25/2012)
6000, Delivered to the customer (8/2/2012)
b_williams_82 is offline   Reply With Quote
Old 09-28-2012, 02:38 PM   #12
Stephen12ZL1
Drives: '15 Z/28
10" ring is going to require you use the metco idler relocation bracket as the smaller 50mm lower idler will be sitting too close to the 10" ring. The metco unit is a nice piece but I had difficulty getting mine to clear the upper accessory idler. Of course they had never heard of an issue at metco and I could have ground the clearance into the bracket myself. For now with the 9.55 crank ring the stock idler bracket with the smaller lower 50mm idler is all that is necessary. Make sure you move the lines away from the pulley which will obviously touch if not adjusted. This may only be an issue with an automatic tranny car. They said at the tuner that this boost level is max for stock injectors as I was at the upper most limit for stock injectors.
Old 09-28-2012, 04:31 PM   #13
Nemisis
Mines a m6 and I have the bracket and idler pulley also but I've just been worried about the injectors. Kinda hard to believe with only cai and a 10" pulley I need injectors.
Old 09-28-2012, 04:40 PM   #14
I love the sound of the Supercharger
