Flowmaster Exhaust
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 10-01-2012, 05:35 PM   #29
RobZL1580
Drives: 2013 Camaro ZL1
Originally Posted by Faster12 View Post
I thought I was the only guy with this issue. I noticed this the first time I washed my car. I really would be interested in seeing GM's response.
Nope, I noticed mine after the first wash too, but thought I did not clean well enough, so the next time I washed them even better and still the same problem.
It appears to be a common problem, so let's see how Chevrolet responds.
RobZL1580 is offline   Reply With Quote
Old 10-01-2012, 05:56 PM   #30
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
I'd imagine that's from a tool and a lack of care when bolting the rims on and off. dont the rims need to be taken off by the dealer to remove those spacers or whatever prior to delivery?
DarkneSS is offline   Reply With Quote
Old 10-02-2012, 12:01 AM   #31
04ssSilverado
04ssSilverado's Avatar
Drives: above `12 zl1 #780
Thought I was overreacting.
04ssSilverado is offline   Reply With Quote
Old 10-02-2012, 05:50 AM   #32
alyssasdad
Go VOLS!!!!!
alyssasdad's Avatar
Drives: ZL1 #1344 VR, M6
Originally Posted by Hercules View Post
I meant nothing about your wheels and the cleaning of them. That comment was actually addressed to me, I'm not doing a good enough job. I just have to do a better job cleaning and watch since it's not happening to everyone right away.
Things should be taken care of now, I see Brandon chimed in and is going to try and help. Good Luck!
I understand brother!! Im sure your doing a good job for a normal car,but for a car that puts off 12lbs of brake dust per wheel per 10 miles of driving time its near impossible to keep them clean!!! But they sure look good!!!
1.GOD
2.Family
3.Camaro........& the TENNESSEE VOLS!!!
alyssasdad is offline   Reply With Quote
Old 10-02-2012, 10:12 AM   #33
Speedforhire
Speedforhire's Avatar
Drives: 2013 GRAND SPORT (aka: EREBUS)
The wheels look like that as a result of a poor paint process. I have the bright forged wheels on my 2013 also and they look good in the wheel lug recesses. Not as shiny as the outside, but they look okay.
.......best pic I have right now.
Speedforhire is offline   Reply With Quote
Old 10-02-2012, 10:57 AM   #34
HDRDTD
To me it just looks like typical brake dust accumulation or it's become imbedded in the paint.
That area around teh lug nut is difficult to get in and scrub. At least for me.
HDRDTD is online now   Reply With Quote
Old 10-02-2012, 06:06 PM   #35
JT3640
JT3640's Avatar
Drives: 2012 ZL1, 2012 QX56
I have the exact same thing I thought it was something I did during one of the many many times I cleaned her up.
JT3640 is offline   Reply With Quote
Old 10-02-2012, 09:20 PM   #36
01pewterz28
Camaro Junkie
01pewterz28's Avatar
I believe it's from water settling in the lug nut area a combination of left over brake dust coming off the lugs settling with the water plus thin paint on the wheels causing the eating away of the paint.
The only 2 ways to prevent this is use compressed air each time the wheel is wet or get some of the 3M material they use for the clear bra and custom cut it for the lug areas.
**FIFTY HBM 2SS VERT**
01pewterz28 is online now   Reply With Quote
Old 10-02-2012, 10:14 PM   #37
Nailn it
Drives: 2013 ZL1 Ashen Gray / Manual
Mine is definitely a paint issue. Bare metal showing with a little overspray. There's no denying it. I didn't make a big deal because eventually going aftermarket and using these for some slicks!
Nailn it is offline   Reply With Quote
Old 10-02-2012, 10:28 PM   #38
BOWTIEBOB
BOWTIEBOB
BOWTIEBOB's Avatar
Drives: 13 ZL1 Vert,13 427 ,11 2SS,15 Z06
I have the same wheels (20" 5 spoke bright alum.) on my 2013 ZL1 Convt. Although I do not have this problem it can be caused by several things I have encountered before. Factory defect by improper coating protection. I have also seen brand new alum. wheels permanently damaged during dealer delivery prep. by utilization of improper low ph acidic chrome cleaner being used to clean the aluminum clear-coated surface. This damage is covered by the 36/36 bumper to bumper warranty for external corrosion on outer surfaces of vehicle. Do not let anyone jerk you around. Threaten them w/ arbitration if you are not given new wheels. You paid mucho bucks for new, undamaged, not repaired by refinishing by an outside source. Such a repair is only covered for 90 days. Insist on NEW wheels. I am on my third set of chrome wheels on my 2009 Avalanche LTZ that corroded and the new replacements were already pitted when they put them on. That is how I became so familiar with dealing with the dealers and Chevrolet. If they give you new wheels, do not clean w/ household cleaners, scour pads or any commercial wheel cleaner (especially those designed to dissolve brake pad dust) that is labeled for use on anything other than coated aluminum wheels. Good luck!
BOWTIEBOB is offline   Reply With Quote
Old 10-02-2012, 10:38 PM   #39
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat (sold)
Originally Posted by YUBslow View Post
You guys better sell those rims before they get worse! I will be generous and buy them from you as to relieve you from this terrible burden!
+1
All seriousness I hope you guys get everything worked out.
FINALLYSATISFIED is offline   Reply With Quote
Old 10-02-2012, 11:41 PM   #40
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
looks like damage from agressive wheel cleaner not rinsed off properly.
My wheels are the bright wheels, and other than brake dust between washings, they look great.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 10-03-2012, 06:42 AM   #41
01pewterz28
Camaro Junkie
I use soap and water only on mine others have posted that is all they use as well.
Old 10-03-2012, 01:20 PM   #42
Pgoldston
Drives: 1999 camaro
Its a paint issue! There are several sets of wheels both aluminum and black that have the exact same powder coating issue
You can lead a horse to water but you cant force people to look at the data
Pgoldston is offline   Reply With Quote
