Gen5DIY
Old 09-30-2012, 03:00 PM   #1
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
P0532E and P023F Engine Codes
Does anyone know what the P0532E code is? I know P0532 is 'A/C Refrigerant Pressure Sensor Circuit Low Input'.
Does anyone know how to disable the P023F code? I could not delete it on HPT? I'm running and Aeromotive fuel setup, so of course the FPCM is not reading in the BCM.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 09-30-2012, 06:36 PM   #2
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
P023e charge air cooler coolant pump control circuit high
P023f manifold absolute pressure turbocharger/supercharger boost sensor "A" correlation.
P0532E is not listed
MMC is offline   Reply With Quote
